Physical Chem Van der Waals eqn of state
In summary: Your Name]In summary, to convert the virial equation of state to the van der Waals equation, we can follow these steps: multiply both sides by V, expand and rearrange the terms, factor out a common term of RT, equate the two equations and compare the coefficients. By substituting the given values of B and C, we can find the values of a and b for the van der Waals equation.
Goronchem
Use the “virial equation of state”. Measurements for Ar gave B = -21.7 cm3/mol and C = 1200 cm6 /mol-2. Assuming that Ar is a van der Waals-type gas, what are the values of “a” and “b” in the corresponding van der Waals
equation of state
PV= RT(1+ B/V +C/V^2 ...)
[p+(a/V^2)][V-b]= RT
I have to convert the virial equation of state to the van der waals equation i think, but am unsure how to do it. It's been some time since my last calculus course so any help would be appreciated!
Hello fellow scientist,
To convert the virial equation of state to the van der Waals equation, we can use the following steps:
1. Start with the virial equation of state: PV = RT(1 + B/V + C/V^2 + ...)
2. Multiply both sides by V to get rid of the fraction on the right side: PV^2 = RT(V + B + C/V + ...)
3. Expand the brackets and rearrange the terms: PV^2 = RTV + RTB + RTC/V + ...
4. Subtract RTV from both sides: PV^2 - RTV = RTB + RTC/V + ...
5. Factor out a common term of RT from the right side: PV^2 - RTV = RT(B + C/V + ...)
6. Now we can see that the left side is similar to the van der Waals equation: PV^2 - RTV = (p + a/V^2)V - bV
7. Equate the two equations and compare the coefficients: p = PV^2 - RTV, a = RT, b = RTB
8. Substitute the given value of B = -21.7 cm^3/mol into the equation to find the value of a: a = (8.314 J/mol*K)(-21.7 cm^3/mol) = -179.9 cm^3*J/mol*K
9. To find the value of b, we need to convert the units of C from cm^6/mol^2 to m^6/mol^2. This can be done by dividing C by 10^6: C = 1200 cm^6/mol^2 = 1.2*10^-3 m^6/mol^2
10. Now substitute the values of a and C into the equation for b: b = (8.314 J/mol*K)(1.2*10^-3 m^6/mol^2) = 9.976*10^-3 m^3*J/mol*K
Therefore, the values of a and b for the van der Waals equation of state are: a = -179.9 cm^3*J/mol*K and b = 9.976*10^-3 m^3*J/mol*K.
I hope this helps and let me know if you have any further questions. Keep up the good work!
Related to Physical Chem Van der Waals eqn of state
1. What is the Van der Waals equation of state?
The Van der Waals equation of state is a mathematical equation used to describe the behavior of gases. It is an improvement upon the ideal gas law, taking into account the volume of gas molecules and attractive forces between them.
2. What are the variables in the Van der Waals equation of state?
The Van der Waals equation of state includes three variables: pressure (P), volume (V), and temperature (T). These variables are used to calculate the behavior of a gas in non-ideal conditions.
3. How does the Van der Waals equation of state account for intermolecular forces?
The Van der Waals equation of state includes two correction factors, a (attractive) and b (repulsive), which account for the attractive and repulsive forces between gas molecules. These factors are added to the ideal gas law to account for deviations from ideal behavior.
4. When is the Van der Waals equation of state most useful?
The Van der Waals equation of state is most useful for studying real gases at low temperatures and high pressures. It is particularly accurate for gases that are close to their boiling point, where intermolecular forces are strongest.
5. How does the Van der Waals equation of state compare to other equations of state?
The Van der Waals equation of state is a semi-empirical equation, meaning it is based on experimental data and theoretical assumptions. It is more accurate than the ideal gas law, but it still has limitations and does not account for all factors that affect gas behavior. Other equations of state, such as the Redlich-Kwong equation, may be more accurate for specific gases or conditions.
28K
  • Classical Physics
  • Quantum Physics
  • Classical Physics
