Physical Chemistry: Kinetics and fluorescence
In summary, we discussed fluorescence in the presence of a quenching molecule, where quenching refers to the removal of energy from an excited electronic state by collision. We also looked at a mechanism for this system and found expressions for the steady state concentration of electronically excited molecules and for If, the intensity of fluorescence. To find the ratio kf/kq, we can use the given data and the equation from part (b). And finally, we can use the given data to find kf/kq by plotting If vs. M and using the slope of the line.
Ki-nana18
91
Consider fluorescence (light emission from an electronically excited state of a molecule) in the presence of a quenching molecule M. Quenching refers to the removal of energy from an excited electronic state by collision, and so without light emission. A mechanism for such a system can be given as follows:
A + hν → A* rate = ke [A] (2.1)
A* + M → A + M rate = kq [A*] [M] (2.2)
A* → A + hν' rate = kf [A*] (2.3)
where the rates of each individual step have been given. In the above expressions ke is the rate constant for formation of electronically excited molecules, is the intensity of the light source used to excite molecules, kq is the rate constant for quenching of molecules, and kf is the rate constant for fluorescence.
a) Find an expression for the steady state concentration of electronically excited molecules, [A*]ss.
b) We may assume that If, the intensity of fluorescence, is proportional to [A*]ss, the steady state concentration of electronically excited molecules. Call the (unknown) constant of proportionality c (so If = c [A*]). Find an expression for If in terms of c and other constants.
c) Based on your answer in b, suggest an experimental method for finding kf/kq, the ratio of the rate constants for fluorescence and quenching.
d) Use your answers above to analyze the data given below. Note that you can use the half-life measured for fluorescence in the absence of quenching molecules to find kf, which makes it possible to find a value for kq.
M (mol/L) If (au) au = arbitrary units
0.0010 0.41
0.0050 0.25
0.0100 0.16
In the absence of any quenching molecules M the half-life for fluorescence is t1/2 = 29. μs.
-N/A
(a)d/dt=ke[A]-kq[A*][M]-kf[A*]=0
(b)I'm completely lost on this part, but I feel that I have to do some sort of substitution and then algebraic manipulation.
(c) I have no idea.
(d)Completely lost.
I only want to know if I'm right on part (a). And if I'm headed in the right direction for (b).
Hello!
(a) Your expression for the steady state concentration of electronically excited molecules, [A*]ss, is correct.
(b) To find an expression for If in terms of c and other constants, we can use the steady state concentration of electronically excited molecules from part (a) and the given equation If = c[A*]. Substituting [A*]ss into this equation, we get If = c[A*]ss. And from part (a), [A*]ss = ke/(kq[M] + kf). So the expression for If in terms of c and other constants is If = c*ke/(kq[M] + kf).
(c) To find the ratio kf/kq, we can use the equation from part (b) and the given data. We know that If = c*ke/(kq[M] + kf), and we have values for If, c, ke, and I from the data. So we can substitute these values into the equation and solve for kq. Then, we can use the value of kq to find kf/kq.
(d) Using the given data, we can plot If vs. M and use the slope of the line to find kf/kq. The slope of the line is equal to c*ke/(kq[M] + kf). And from the given data, we know the values of If, c, ke, and I. So we can rearrange the equation to solve for kq, and then use the value of kq to find kf/kq.
I hope this helps! Let me know if you have any further questions.
Related to Physical Chemistry: Kinetics and fluorescence
1. What is physical chemistry?
Physical chemistry is a branch of chemistry that deals with the study of the physical properties and behavior of matter at the atomic and molecular level. It combines principles of physics and chemistry to understand and explain the fundamental nature of matter and its interactions.
2. What is kinetics in physical chemistry?
Kinetics in physical chemistry is the study of the rates of chemical reactions and the factors that influence them. It involves the measurement and analysis of reaction rates, as well as the development of mathematical models to describe the behavior of chemical reactions.
3. How is kinetics related to fluorescence?
Fluorescence is a type of spectroscopy that is commonly used in kinetics studies. It involves the emission of light by a substance when it is excited by a specific wavelength of light. This technique is often used to monitor the progress of a reaction and to determine reaction rates.
4. What is fluorescence lifetime in physical chemistry?
Fluorescence lifetime is a measure of the average time that a molecule remains in an excited state before returning to its ground state. It is an important parameter in fluorescence spectroscopy and can provide information about the chemical environment and interactions of a molecule.
5. How is physical chemistry used in practical applications?
Physical chemistry has many practical applications in fields such as materials science, environmental science, and pharmaceuticals. It is used to design and optimize new materials, understand and control chemical reactions, and develop new drugs and treatments. It also plays a crucial role in the development of renewable energy sources and environmental remediation techniques.
  • Other Physics Topics
  • Differential Equations
