Physical degrees of freedom of an Electromagnetic field
In summary, the classical source-free electric and magnetic wave equations are solved by solutions for the electric and magnetic fields that have the following form:
Frank Castle
580
23
As I understand it, the classical source-free electric, ##\mathbf{E}## and magnetic, ##\mathbf{B}## wave equations are solved by solutions for the electric and magnetic fields of the following form: $$\mathbf{E}=\mathbf{E}_{0}e^{i (\mathbf{k}\cdot\mathbf{x}-\omega t)}$$ $$\mathbf{B}=\mathbf{B}_{0}e^{i (\mathbf{k}\cdot\mathbf{x}-\omega t)}$$
Naively counting the degrees of freedom (dof) at this point it would appear that the electromagnetic field has 6 dof.
However, is it correct that Maxwell's equations provide 4 constraints: $$\mathbf{k}\cdot\mathbf{E}_{0}=0 \\ \mathbf{k}\cdot\mathbf{B}_{0}=0$$ $$\mathbf{E}_{0}=-\frac{1}{\sqrt{\mu_{0}\varepsilon_{0}}}\mathbf{k}\times\mathbf{B}_{0}$$ and $$\mathbf{B}_{0}=\sqrt{\mu_{0}\varepsilon_{0}}\mathbf{k}\times\mathbf{E}_{0}$$
Thus reducing the number of physical dof to 2?!
If the above is correct what do these remaining dof correspond to? Are they simply the two possible polarisation (unit) vectors ##\mathbf{\epsilon}_{1}##, ##\mathbf{\epsilon}_{2}## that one can construct such that $$\mathbf{k}\cdot\mathbf{\epsilon}_{1}=\mathbf{k}\cdot\mathbf{\epsilon}_{2}=0$$ and $$\mathbf{k}\times\mathbf{\epsilon}_{1}=\mathbf{\epsilon}_{2}\\ \mathbf{k}\times\mathbf{\epsilon}_{2}=-\mathbf{\epsilon}_{1}$$ and hence ##\lbrace\mathbf{k},\;\mathbf{\epsilon}_{1},\;\mathbf{\epsilon}_{2}\rbrace## form an orthornormal basis, such that the general solutions for ##\mathbf{E}## and ##\mathbf{B}## are linear combinations of ##\mathbf{\epsilon}_{1}## and ##\mathbf{\epsilon}_{2}##?!
Likes vanhees71
marcusl said:
Ok cool.
So are the two physical degrees of freedom simply the choice of a component for the polarisation ##\mathbf{\epsilon}_{1}##, and the choice of a component for the polarisation vector ##\mathbf{\epsilon}_{2}## (in principle, they both have 3 dof, but the requirement that ##\mathbf{k}\cdot\mathbf{\epsilon}_{1}=\mathbf{k}\cdot\mathbf{\epsilon}_{2}=0## and ##\mathbf{\epsilon}_{1}\cdot\mathbf{\epsilon}_{2}=0##, reduces their dof to one each)?
Yes, that's a nice way to put it.
Great. Thanks for your help.
FAQ: Physical degrees of freedom of an Electromagnetic field
1. What are physical degrees of freedom of an Electromagnetic field?
The physical degrees of freedom of an Electromagnetic field refer to the different types of movements or vibrations that the field can possess. These include the electric field, magnetic field, and the direction of propagation.
2. How many physical degrees of freedom does an Electromagnetic field have?
An Electromagnetic field has two physical degrees of freedom - the electric field and the magnetic field. These two fields are perpendicular to each other and to the direction of propagation, resulting in a total of three dimensions of movement.
3. What is the significance of physical degrees of freedom in an Electromagnetic field?
The physical degrees of freedom in an Electromagnetic field determine its behavior and interactions with matter. For example, the electric field is responsible for the attraction or repulsion of charged particles, while the magnetic field is involved in the alignment of magnetic materials.
4. Can the physical degrees of freedom of an Electromagnetic field be changed?
Yes, the physical degrees of freedom of an Electromagnetic field can be altered by changing the properties of the field, such as its frequency, amplitude, or direction of propagation. This can be achieved through various methods, such as using lenses, filters, or polarizers.
5. How do the physical degrees of freedom of an Electromagnetic field relate to light?
Light is a type of Electromagnetic field, and therefore has the same physical degrees of freedom - the electric and magnetic fields. The properties of these fields determine the characteristics of light, such as its color, polarization, and intensity.
