Physical infinities, what are the limitations?
  • Thread starter iDimension
  • Tags
    Physical
In summary, the conversation discusses the concept of multiple infinities existing in the physical world and the possibility of two or more infinite objects coexisting at the same time. It also touches on the idea of an infinite universe and the potential for multiple universes to exist simultaneously. The conversation also delves into the mathematical concept of infinity and its use in scientific models. Overall, the conversation highlights the complexity and potential limitations of understanding and comprehending infinity in the physical world.
iDimension
108
From a mathematical point of view there can and is many different infinities that exist. I'm curious what happens when we try to use a physical infinity in cosmology. I'm not going to lie I don't even think my brain is capable of comprehending this but can two physical infinities exist simultaneously?
How can two objects which occupy the same volume both be infinite at the same time? If they can't both be infinite at the same time then how can it be that two, three, four or 10500 universes can exist, all of them being infinite and all of them existing at the same time?
If one object is infinite in volume then it stands to reason that there is not more volume left over for another another to coexist.
If it is somehow possible for another infinite universe to coexist, then where is it located? In some sort of external meta-space or something?
First of all, we do not yet know whether our universe is finite or infinite.
Second, any sort of "multiple universe" business is not a well established mainstream physical theory.
Therefore, it is premature to discuss how multiple infinite universes can co-exist (and this is also against the rules of this forum).
But infinite objects, in general, can co-exist. Take two straight lines. They are infinite, yet you can have as many as you want.
They can be removed from each other in higher dimensions. Just like you can have infinitely many infinitely long lines on a 2d plane, or infinitely many 2d planes in 3d space.
But how can infinitely many 3d objects coexist?
Btw physical 1d and 2d objects don't actually exist.
Why shouldn't they be able to? There is an infinite amount of room for them to exist in (if our universe is infinite in size).
I love the title of this thread. Infinities, where does it end?
Because if an object is infinite then by it's very definition that object must be everything that can exist otherwise that object is not infinite. What you are suggesting is that there can exist infinitely many finite objects which is allowed but not more than 1 singular object whos size is infinite.
Consider flipping a single coin an infinite number of times. There can only be 1 set... the infinite set. You can't have the set ##A={h,h,h,h\cdots\infty}## and ##B={t,t,t,t\cdots\infty}## because each set itself is infinite.
So you would need more than 1 coin if you wanted to create 2 sets. The same goes for an infinite object, the infinite object takes up infinite volume leaving no volume for another object.
That is the definition of "everything", not of "infinite".
Counterexample: there are infinitely many odd numbers, yet there are also numbers that are not odd.
Counterexample: consider an infinitely long rod of radius 1 meter. There's plenty of space around the rod for other objects.
Sixty Symbols recently posted a video about infinities.
Who said any object was infinite? An infinite number of objects is not the same as an infinitely sized object.
It is very important to distinguish infinity as a term in mathematics from any physical concept of infinity.
For flipping the coins, why do I have the feeling the set is pretty much finite?
It's either h or t...
so your Whole set is [itex]W= \left\{ h,t \right\}[/itex]
Now either you drop t, or h for infinite times, they will still exist in W, which is obviously finite and has (set) order [itex]2 \ll ∞[/itex].
Nobody has said anything is infinite but I said if our universe is infinite.
You asked about an object of infinite size, but your original question was about the universe being infinite, not an object. Note that the universe isn't a singular, physical object. Empty space exists within the universe, so a universe of infinite size has an infinite amount of space for objects to exist within.
Your questions are too vague and not what physics is about. Physics and science is about making measurements and models that explain the measurements in a simple way. Sometimes models use infinity, and it's just a number to make the model work better. I blame popular science writers for getting people to focus on this meaningless stuff.
So you're saying that everything and anything that exists is finite? Which can't possibly be true. The only possibly way I can see finite being true is that it s physically impossible to travel behond this finite object but then one must ask how?
I just find it impossible to believe or comprehend how something can be all that exists and be finite. Help me understand :confused:
The last was a word-play?
If "all that exists" is finite, then that something ,which is "all that exists", is finite.
Take for example all the water on earth, it's all the water there is on earth, but both its vollume and Earth's vollume is finite.
Now about infinity, I don't really like it... I think infinity in physics means some very large value of a quantity... The bad infinities appearing not as limits, are problematic for the theories. However that's a theory (mathematical) concern and it's not actually measured in experiments.
Related to Physical infinities, what are the limitations?
1. What is the concept of physical infinity?
The concept of physical infinity refers to the idea that certain quantities or phenomena in the physical world may have no defined limit, either in terms of their size or duration. This can include infinite space, infinite time, or infinite energy.
2. Are there any observed examples of physical infinities?
There are currently no observed examples of physical infinities in the natural world. While some phenomena, such as the expansion of the universe, may seem to approach infinity, they are still subject to certain limitations and boundaries.
3. What are the limitations of physical infinities?
The limitations of physical infinities are not fully understood, as they are still a topic of ongoing scientific research. However, some theories suggest that the laws of physics may break down at extreme scales, preventing the existence of true infinities.
4. How do physical infinities impact our understanding of the universe?
The concept of physical infinities challenges our current understanding of the universe and forces us to question the limitations of our scientific knowledge. It also raises important philosophical questions about the nature of reality and the universe as a whole.
5. Can we ever truly understand physical infinities?
As our understanding of the universe and the laws of physics continues to evolve, it is possible that we may eventually gain a better understanding of physical infinities. However, it is also possible that some aspects of infinity may remain beyond our comprehension.
  • Other Physics Topics
  • Cosmology
