A Physical interpretation of hopping between orthogonal orbitals
  • A
  • Thread starter Thread starter hokhani
    Electric Field
hokhani
TL;DR Summary
What causes hopping between orthogonal orbitals?
Suppose two orthogonal neighbouring orbitals ##|\phi _1 \rangle## and ##|\phi _2 \rangle## so that ##\langle \phi_1|\phi _2 \rangle =0##. Applying an electric field adds a new term ##u (c_1^{\dagger}c_1-c_2^{\dagger}c_2)## to the Hamiltonian which u is a constant potential. Obviously, we still have the hopping as ##\langle \phi_1|u (c_1^{\dagger}c_1-c_2^{\dagger}c_2)|\phi _2 \rangle =0##. I would like to know how the hopping arises between the two neighbouring orbitals.
Cross terms including ##c_2^{\dagger}c_1##, etc. seems required.
Right, but my question is how this term may arise?
A familiat perterbation Hamiltonian in applying electric field is
H'=eEx
where
x=\sqrt{\frac{\hbar}{2m\omega}}(c+c^\dagger)
I do not have enough knowledge of your system ##|\phi_1>,|\phi_2>##.
hokhani said:
TL;DR Summary: What causes hopping between orthogonal orbitals?
The orbital are assumed to be orthogonal for convenience but in the true Hamiltonian they are not. There is some overlap, it is considered tiny but it is this overlap that allows hopping. Check the tight-binding theory.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
