Physical pendulum in phase space
In summary: But it isn't. The reason is that, in the original microcanonical ensemble, there are states with very small energies that are almost always excluded from the larger region. In summary, the area of possible states in some range of energies of a pendulum in phase space is conserved due to Liouville's theorem. But at the end there is all new bigger area uniformly filled up. So both can't be right, and I think that the area in the phase should be conserved. But don't know how to solve the argument with uniformly filled up the new bigger area which is in agreement with
lakmus
23
Hi,
I found out this paper
http://www.pha.jhu.edu/~javalab/pendula/pendula.files/users/olegt/pendulum.pdf
with this animation
http://www.pha.jhu.edu/~javalab/pendula/pendula.files/users/olegt/pendula.html
At first there is written there, that the area of possible states in some range of energies
of pendulum in phase space is conserved due to Liouville's theorem. But at the end there
So both can't be right, and I thing that the area in the phase should be conserved. But don't
know hot to solve the argument with uniformly filled up the new bigger area which is in agreement
with equillibrium statistical physics of microcanonical ensembles . .
Thanks a lot for any response!
It is uniformly but not completely filled up. Think of it like fine stripes across phase space.
Likes 1 person
Ok, well, what if I choose just some (not all) states with exact value of energy. These would be bounded on movement on this equipotencial (in pendulum case some curve). Will these also spread over whole curve, or not?
I would have to work the math, but I believe not. I think that it is the variation in energy that causes the spread. Without that I think they would just cycle around.
I think the same also. But in this case the distribution would not be an uniform - in the definiton of microranonical ensamble, is that the system have constant energy and in that case, in equilibrium all state have the same probability, so the equilibrium distribution function is uniform . . . so this doesn't work for the pendulum (or more clearly for the aproximative math pendulum).
So where is the problem?
I am not sure what you are concerned about. If you have a microcanonical ensemble for a given energy then you have all of the states at a given energy. As those evolve over time you will continue to have all of the states for the same energy. So a microcanonical ensemble at one point in time looks the same as the microcanonical ensemble at any point in time. In that case, Louiville's theorem is trivially and clearly satisfied.
And what about and izolated box with a gas of given energy, where at first is not equilibrium - half slow molecules and half fast, will evolving into more "homogenized" state, right?
Yes, but an isolated box with a gas of a given energy with half slow and half fast molecules is not a microcanonical ensemble. It is a single microstate within that ensemble. It will evolve to another microstate within that ensemble, and there are many more microstates which are "homogenized" than not.
But microcanonical ensamble define by box of gas of certain enenergy will evolving in phase diagram to uniform distribution function, but the microcanonical ensamble define by pendulum at certain energy will not. This is how i get it know, and my intuition says, that not correct . . .
A single box of gas at a certain energy is not a microcanonical ensemble. The microcanonical ensemble is the set of all possible boxes of gas with the same energy. One box is just one microstate out of the ensemble.
Yes, sure your right, wrong terminology. So let's have two izolated systems - pendulum and box with gas. We choose some subset of all posiblle states with constant given energy and watch its development in phase space.
We agreed that the pendulum will just rotate and nothink else happen.
But what will happen with the subset of all posiblle states from the box with gas?
In both cases you start with a subset of the microcanonical ensemble, and the systems both evolve to a different subset of the same microcanonical ensemble. There is no difference between the pendulum and the box in that respect.
Now, let's suppose that we partition the phase space into two regions, one much larger than the other, and let's further suppose that the original subset of each microcanonical ensemble comes entirely from the smaller region. Now, if we let each state evolve for a random amount of time and test to see if it winds up in the small or the large region then we will find that it is much more likely to end up in the large region, despite the carefully chosen initial conditions. Again, there is no difference between the pendulum and the box in this respect.
The only difference between the pendulum and the box is that the phase space for the box can be partitioned into "high entropy" and "low entropy" partitions, while the pendulum cannot.
Likes 1 person
It kind a look like, that treating the pendulum from a statistical point of view does not have any sense . . .
But anyway, thanks a lot. Discussion with you really helped a lot.
I agree. The phase space is too simple for a statistical treatment to be worthwhile.
Related to Physical pendulum in phase space
1. What is a physical pendulum?
A physical pendulum is a type of pendulum that consists of a rigid body suspended from a fixed point and is able to oscillate back and forth due to the force of gravity.
2. What is phase space?
Phase space is a mathematical concept that describes the space in which all possible states of a physical system can be represented. In the case of a physical pendulum, phase space consists of position and momentum values of the pendulum.
3. How is a physical pendulum represented in phase space?
A physical pendulum is typically represented in phase space using a phase portrait, which is a graph that shows the trajectory of the pendulum's motion over time. The position and momentum values of the pendulum are plotted on the x and y axes, respectively.
4. What is the relationship between a physical pendulum and its phase space representation?
The phase space representation of a physical pendulum provides a visual representation of the pendulum's motion and can help to predict its behavior. It also allows for the analysis of the pendulum's energy and angular momentum, which can be important in understanding its overall behavior.
5. How does the energy of a physical pendulum change in phase space?
In phase space, the energy of a physical pendulum remains constant as the pendulum oscillates back and forth. However, the distribution of energy between kinetic energy (motion) and potential energy (position) changes as the pendulum moves through different points in its trajectory.
  • Thermodynamics
  • Astronomy and Astrophysics
  • Beyond the Standard Models
