Physical Pendulum - Rod - Period and Distance From Center of Mass
In summary, the homework statement states that there exist two values of a (a1, a2) for which the pendulum oscillates with the same period. T = 2\pi\sqrt{\frac{J}{mga}} is derived and explained as being the smallest period when the pendulum is hung from its center of mass.
ing_it
27
We have a rod (length L, mass m) suspended at a point whose distance from the center of mass is a.
1) prove that (generally) there exist two values of a (a1, a2) for which the pendulum oscillates with the same period.
2) derive and explain: [tex] T = 2\pi\sqrt{\frac{a_1+ a_2}{g}}[/tex]
3) with what value of a do we get the smallest period?​
[tex] E = 1/2 I w^2 [/tex]
[tex]J= J^* + ma^2[/tex]
[tex]J= 1/12 mL^2 + ma^2 [/tex]
[tex] T = 2\pi\sqrt{\frac{J}{mga}}[/tex]
[tex] T = 2\pi\sqrt{\frac{L}{g}}[/tex]
1) I thought that two periods being the same would mean T1 = T2
[tex] 2\pi\sqrt{\frac{J_1}{mga}}= 2\pi\sqrt{\frac{J_2}{mga}}[/tex]
[tex]J^* + ma_1^2 =J^* + ma_2^2[/tex]
[tex]a_1^2 =a_2^2[/tex]
[tex]a_1 = +/- a_2[/tex]
and since a1 = a2 would be the same location a1 = - a2 which would mean that the only way to get the same period for two different values of a, would be to have the a be the same but in different directions from the center of mass.
2) I noticed that [tex] T = 2\pi\sqrt{\frac{a_1+ a_2}{g}}[/tex] looks a lot like [tex] T = 2\pi\sqrt{\frac{L}{g}}[/tex]
So I thought that a1 + a2 = L
and that that would mean that the rod would be suspended on one end and the mass would be concentrated on the other end of the rod? I guess it sounds silly but I just couldn't figure out anything else.
3) [tex] \lim_{x\rightarrow 0} T = 2\pi\sqrt{\frac{J}{mga}} = 2\pi\sqrt{\frac{1/12 L^2 + a^2}{ga}} [/tex]
since [tex] 2\pi\sqrt{\frac{1}{g}} [/tex] is a constant I'll derive the rest because a limit is just a special type of derivation (I think?)
[tex] \frac{1/2 L^2 + a^2}{a}[/tex] derived is:
[tex] La + a^2 + {\frac {L^2}{2}}[/tex]
and from that I can see that the smaller the a the smaller the period of the oscillation so we would get the shortest period if the pendulum was hung from its center of mass.I was told my solution is wrong. I don't know which parts, I don't know why and I don't know how to correct it. If you could help me out somehow I'd be really grateful.​
ing_it said:
T=2π√(J/mgr)
where r represents...?
Likes ing_it
That would be the distance between the point of rotation and the center of mass. Sorry, I got it from a different problem and messed it up. It should be a.
It affects the first equation, but the way I reasoned the error wouldn't make a difference.
I'm going to go edit it so it fits this problem.
but there is no 'a', there is a1 and a2, so it does make a difference.
Likes ing_it
Oh, okay so in the first part of my problem I can't just disregard the mga anymore because one is mga1 and the other mga2. That will completely change the problem, you're right!
Thank you :) I'm going to try to fix it.
Okay so calculating
[tex]2\pi\sqrt{\frac{J^* + ma_1^2}{mga_1}}= 2\pi\sqrt{\frac{J^* + ma_2^2}{mga_2}} [/tex]
[tex] {\frac{J^* + ma_1^2}{mga_1}}= {\frac{J^* + ma_2^2}{mga_2}} [/tex]
J* for a rod is:
[tex] J^* = {\frac{mL^2}{12}}[/tex]
[tex]{\frac{L^2}{12 a_1}} + a_1= {\frac{L^2}{12 a_2}} + a_2 [/tex]
[tex]{\frac{L^2}{12}} ({\frac{1}{a_1}} - {\frac{1}{a_2}})= a_2 - a_1 [/tex]
we can divide that by the [tex]({\frac{1}{a_1}} - {\frac{1}{a_2}})[/tex]
and get [tex]{\frac{L^2}{12}} = a_1 a_2[/tex]
which means that [tex] a_1 = {\frac{L^2}{12 a_2}}[/tex]
Is that correct? Am I missing a +/- from the removal of the square root? And adding that will mean that it is true weather we go to the right from the center of mass or the left.
So this tells me that there is some correlation between the two distances but that it doesn't mean that they are the same length away from the center of mass?
Assuming my calculations for a1 and a2 are correct now. I can plug that into
[tex]
I have decided that I shouldn't be mixing a simple pendulum [tex]
T = 2\pi\sqrt{\frac{L}{g}} [/tex]
into this and instead I did this
[tex]2\pi\sqrt{\frac{ a_1+ a_2}{g}} = 2\pi\sqrt{\frac{J}{mga_2}}[/tex]
[tex]2\pi\sqrt{\frac{ {\frac{L^2}{12 a_2}}+ a_2}{g}} = 2\pi\sqrt{\frac{ {\frac{mL^2}{12}} + ma_2^2 }{mga_2}}[/tex]
after simplifying I got 1=1 sooo that means that it's true... but I can't figure out what that means.
I mean... a pendulum can't be hanging from two points at once so what IS the a1 + a2? Or does the 1=1 just mean that the whole "formula" that was in the problem statement is just the period calculated while hanging from one of the points?
I did not understand part 2 at first because T has not been defined. I suppose it must mean where T is the period for either a1 or a2, and that appears to be what you have shown.
As for how to interpret it, think of it in terms of an equivalent simple pendulum.
Likes ing_it
Oh yes, well we weren't given an explanation as to what it was but I assumed that the T is the period.
So, what it says is that a simple pendulum that is L2/(12a2) + a2 long would have the same period as our physical pendulum?
Thank you so much for your help!
Do you have any idea what kind of mistake I made in the third point of the problem? I read this post and tried to follow the instructions given to the OP but OP never followed up and I guess I misunderstood something.
No, how do you get that?
What is the period of a simple pendulum of length a1+a2?
For part 3, you found a simple relationship between a1 and a2 in post #5. With that constraint, find the minimum of the period given by the expression in part 2.
Well my reasoning was that since the period for a simple pendulum looks like this [tex]
[/tex]
and the equation for a physical pendulum hanging from a point a2 away from the center of mass can be written like this: [tex]
[/tex]
and since the equations are so similar I figured that a1+a2 = L and from that I figured that a pendulum hanging at a distance of a2 to the center of mass would have the same period of an oscillation as a simple pendulum of length L= a1 + a2
isn't the period of a simple pendulum of the length (a1 + a2) this? : [tex]
[/tex]
I tried: [tex]
T = 2\pi\sqrt{\frac{a_1+ a_2}{g}} =0
[/tex]
[tex]{\frac{L^2}{12 a_2}} + a_2 = 0[/tex]
but after "cleaning it up" I would get something impossible
[tex] a_2 = sqrt {{\frac{- L^2}{12}}}[/tex]
I tried derivating it and then putting it equal to 0 but then I just couldn't free the a2
[tex] 2 L a_2 - L^2 + 12 a_2^2 =0 [/tex]
Ah, ok, yes. I didn't recognise it in the more complicated version you had in post #8. This way of wording it is much clearer.
ing_it said:
##T = 2\pi\sqrt{\frac{a_1+ a_2}{g}} =0##
T=0?! You are asked to minimise it, but it won't reach zero.
Likes ing_it
Okay I did more searching online and I think I was making a mistake in my drivation anyway but there is what I came up with:
[tex] {\frac{dT}{da}} = 0[/tex]
I'm going to go ahead and leave out the constants because I calculated with them and they all "disappeared" anyway
[tex] [{\sqrt{{{\frac{L^2}{12 a_2}}+ a_2}}}]' = 0 [/tex]
[tex]{\frac{{\frac{L^2}{-12 a_2^2}}+1}{{\frac{1}{2}}{\sqrt{{\frac{L^2}{12 a_2}}+a_2}}}}=0[/tex]
since for a fraction to equal 0, the top needs to be equal to zero that means
[tex]{\frac{L^2}{-12 a_2^2}+1}=0[/tex]
[tex]L^2 - 12 a_2^2 = 0[/tex]
[tex]a_2={\sqrt{{\frac{L^2}{12}}}}[/tex]
and so that last a2 would be the distance from L for the minimal period?
It is certainly unsurprising that the case a1=a2 represents a local extremum, but you need to check whether it is a minimum or maximum.
Likes ing_it
To do this would I do the second derivative of [tex]
-24a2 and then if that is smaller than 0 it's a local maximum and if it's greater than 0 then it is a local minimum? so in this case it would be a local maximum?
But now that I look at it I could have
[tex]
-L^2 -+12 a_2^2 = 0[/tex]
and it would still be correct and then I'd end up with 24a2 which would be a minimum
which means my logic is flawed.
[tex]
You can simplify the problem a lot. T will be minimised when the sum of the distances is minimised, we don't need to worry about the square root. So the problem reduces to minimising x+y subject to xy=c2. Draw a graph, or consider that (x+y)2=(x-y)2+4xy.
Likes ing_it
I've been trying to figure out what to do with what you've told me but I just don't think I know what you mean or exactly how to calculate it. In math we learned how to find the minimum of a function by making the first derivation equal to zero and then either making a determinant from the second derivations (one with respect to x2 the next xy the one after yx(xy) and the one after that y2) or in some cases we just did a second derivation and if it was smaller than 0 then it was the max and if it was bigger than 0 it was the minimum.
what is xy= c2? is it a1a2 = ?
I am really grateful for all your help but I just can't figure out what to do with this last tip :(
haruspex said:
(x+y)2=(x-y)2+4xy
Given that xy=c2, a constant, and that (x-y)2 cannot be negative, what is the minimum possible value of (x+y)2?
Likes ing_it
(x+y)2 >= c2 ? So... xy would be the minimum?
I notice this thread peterered out here... status ?
Haru's exercise is straightforward: you want to find an x and a y and a minimum vaue for (x+y)2, so the answer xy is not what you are looking for: the minimum has to be some function of c. In fact Haru has put you on top of the answer in #15 (and by now you know how useful a picture can be ! :smile: )
I marked it as answered because in the end I took that L2 - 12a22 and I got a2 = +/-sqrt( L2/12)
and when I put that back into the original problem and got that in both cases it will be >0 and that means that it will be the minimum. In school I was told that it's correct and so I marked it as solved.
Anyway, I never said thank you, but really, thank you Haruspex! I would've never finished this problem without your help :)
BvU said:
All credit to Haru. I just found it a nice thread because (long ago) I had fun with Kater's reversible pendulum to determine ###g##. (or compound pendulum)
Hehe, and I'm not used to the mark as solved gimmick yet.
Oh I didn't actually know what pendulums were/are used for! That's pretty cool.
And as for Kater's pendulum... it sounds even more complex than what I was looking at and this already was pretty difficult for me so I'm glad I just read a wikipedia article about it and didn't have to calculate anything!
Oh that's okay. I didn't know if it was okay to write that it's all good as a reply since I didn't want to just be "bumping" up the thread but I thought that anyone that's helping someone would want to know that whatever they did worked so I clicked the button in hopes that it wouldn't bump it up but that maybe it would notify Haru that his help worked :)
Sorry, I didn't see this post. Thanks to BvU for reviving the thread.
Look at the equation I wrote at the end of post #15 and what I wrote in post #17. Since xy=c2 you can use that to replace xy in first equation. This gives you a relationship between (x+y)2 and (x-y)2.
For eal x and y, what is the lowest possible value for (x-y)2?
Related to Physical Pendulum - Rod - Period and Distance From Center of Mass
1. What is a physical pendulum?
A physical pendulum is a system used to study the oscillations of a rigid body around a fixed axis. It consists of a rigid rod or bar that is free to rotate about a fixed pivot point.
2. How is the period of a physical pendulum calculated?
The period of a physical pendulum is calculated using the equation T = 2π√(I/mgd), where T is the period, I is the moment of inertia of the pendulum, m is the mass of the pendulum, g is the acceleration due to gravity, and d is the distance from the pivot point to the center of mass.
3. What is the center of mass of a physical pendulum?
The center of mass of a physical pendulum is the point at which the entire mass of the pendulum can be considered to be concentrated. It is the point where the pendulum will balance if suspended from that point.
4. How does the distance from the center of mass affect the period of a physical pendulum?
The period of a physical pendulum is directly proportional to the distance from the center of mass. This means that as the distance increases, the period also increases. This is because the greater the distance, the larger the moment of inertia, resulting in a longer period of oscillation.
5. How does the length of the rod affect the period of a physical pendulum?
The length of the rod does not affect the period of a physical pendulum. The period is only affected by the distance from the center of mass to the pivot point and the mass of the pendulum. The length of the rod only affects the amplitude of the pendulum's oscillations.
