Physical properties to the nanoparticles
In summary, nanoparticles are small clusters of material with sizes on the order of a few nanometers and exhibit different properties compared to bulk systems due to phenomena such as quantum confinement. The limit for nanoparticles is around 1 nm, as beyond that size, the particles become simple colloids and lose their unique properties. It is not possible to prepare pico-particles as they would essentially be single atoms. The properties of nanoparticles are governed by factors such as surface to volume ratio, change in band gap, and size compared to electronic wave function.
Erdem
What gives the different physical properties to the nanoparticles than the bulk ones? what is the limit?
is it also possible to prepare pico-particles.
I don't see too much difference.
What's a nanoparticle? What's a picoparticle?
- Warren
Nanoparticles are just small clusters of some material, made up of a "small" number of atoms, and exhibiting sizes on the order of a few nanometers. The difference in properties between the nanoparticles and bulk systems arise from many different phenomena, such as quantum confinement.
An example is silicon. Bulk silicon has extremely poor luminescence (especially in the visible region). However, Si nanoparticles can be created that exhibit photoluminescence across the entire visible spectrum.
And I have never heard of "picoparticles".
A typical nanocrystal consists only of a few 100 (~ 2 nm diameter) to a few 10'000 (~10 nm) atoms. If the size is increased, you lose the quantum confinement effects, and they become simple colloids. Now you can also immediately see that you really can't get much below 1 nm: you'd end up with only a few atoms. At this point you reach the 'cluster'-domain and you lose all properties that belonged to the original material. It's just a molecule at this stage. Any smaller and you'll end up with single atoms, protons, quarks, ...
The Property of a nanoparticle is basically govern by three factors
1. the surface to volume ration
2. the change in band gap
3. the comparable size of the particle with that of electronic wave function.
it not posible to prepare a pico particle. Because beyoud nano it comes only the atoms. so it will deal with the atom not particles
nano
the property of a nanoparticle is govern by generally three factors
2. the change in band gap i.e the band gap of the particle is grater than that of the bulk.
3. the comparable size of the particle to that of the electronic wave function.
we can't prepare pico particle because beyond the nano range it is only the atomic level. in pico range it is deal with the atoms only not the particles.
Mohendra, please do not bring up threads that are years old (check the last posting date before you reply to a thread). All but one of those posters have not visited this site in over 2 years. If you wish to start a new discussion, you may create a new thread.
Related to Physical properties to the nanoparticles
What are nanoparticles?
Nanoparticles are tiny particles with at least one dimension measuring between 1 and 100 nanometers. They can be made of various materials such as metals, polymers, and ceramics.
What are the physical properties of nanoparticles?
The physical properties of nanoparticles can vary depending on their size, shape, and composition. Some common physical properties include surface area, melting point, and optical properties.
How are nanoparticles different from regular-sized particles?
Nanoparticles have unique properties due to their small size, including a larger surface area-to-volume ratio and different chemical and physical behaviors. They may also exhibit quantum effects that are not seen in larger particles.
What are some applications of nanoparticles?
Nanoparticles have a wide range of potential applications in fields such as medicine, electronics, environmental remediation, and energy production. Some examples include drug delivery systems, nanosensors, and solar cells.
What are the potential risks associated with nanoparticles?
While nanoparticles have many promising applications, there are also potential risks to human health and the environment. These include potential toxicity and environmental impacts, which are still being studied and evaluated by scientists.
  • Atomic and Condensed Matter
