Physically what is phase of an Image?
In summary, the phase of an image is the location of a certain feature or pattern within the image, while the magnitude is the overall appearance or intensity. By looking at the phases of the complex coefficients of the Fourier-transform, one can determine the location of a specific feature in the image. This concept can be used for image reconstruction and enhancement, such as sharpening blurred images or recognizing patterns.
ramdas
79
Hello everyone,I want to ask very basic question related to
multidimentional signals like an
image or a video signal.
Physically what is phase of an Image? Also what is its physical significance of phase compared to magnitude of an image?
Mathematics news on Phys.org
In what connection?
The Fourier-transform of an image?
Hesch said:
In what connection?
yes you are right.
Say you have an image which simply repesents a dot exactly in the center of the image ( black background, white dot). You at first fourier-transform this image row by row (horizontally). All the rows, but the centerrow, will be black ( the coefficients to all harmonics will be zero ). But the centerrow will contain a pulse, which will cause that the absolute value of all the (complex) coefficients to the harmonics in this row will be same. As such you know it's a pulse (dot), but you don't know its location.
Now you fourier-transform this first "horizontal" fourier-transform vertically (column by column), and all these vertical fourier-transforms will "see the horizontal line" having the same absolute coefficients. Again, by this vertikal transform, a pulse is seen in every column, which will cause that the absolute value of all the (complex) coefficients to the harmonics in all columns will be same. As such you know it's a pulse (line), but you don't know where it is located.
If you move this original dot in the image, the absolute values ( amplitude/power ) of all the coefficients in the whole image will be the same, but the phases of the complex coefficients to the harmonics will change, so you know the image represents a dot, and by inspection of the phases of these complex coefficients, you know where this dot is located in the image, and you can reconstruct the original image by inverse fourier-transform.
Rough: As for a dot, the absolute amplitudes tells you what it is ( how it looks ), the phases tells you where it is located. As for more complicated images, you can look at them as a sum of dots.
@Hesch Thank very much .But it's very hard to understand the above concept without any image. so if possible can you add few images so that it can be very easy to understand it.
also it's very hard to understand concepts like local phase and global phase,calculation of local phase at each frequency of an image
You cannot make an "image" of the fourier-transform of a spatial image, but you can make a plot, showing the power of (absolute value of the coefficients) in the transform. Below two images of "Guffy" along with a plot of their transforms. Near the center of the plot are shown the power of lower harmonics, and near the edges are shown the power of higher harmonics. Bright dots means high power, dark dots means low power. The left image is sharp, and in the left plot you see some high power near the edges. Now someone has dampened (by computer) the powers in the right plot (has dampened the higher harmonics/frequencies in the image). The right image is a result of an inverse transform of the right plot, and is blurred due to the lack of high frequencies. It's as listening to music with no treble.
Likewise, if you have a blurred photo, you can sharpen it by enhancement of higher frequencies (more treble).
Other purposes: Dynamic contrast enhancement of images and recognition of patterns.https://www.google.dk/search?q=image+fourier+transform&biw=1366&bih=635&source=lnms&tbm=isch&sa=X&ei=gMczVcfkB6X4ywPA-oDoBg&ved=0CAYQ_AUoAQ#imgrc=wvwV4dPWIn0ntM%3A;A2xE7JcqeCmpgM;https%3A%2F%2Fwww.cs.auckland.ac.nz%2Fcourses%2Fcompsci773s1c%2Flectures%2FImageProcessing-html%2Ffourier_files%2Fgoo_comp.gif;https%3A%2F%2Fwww.cs.auckland.ac.nz%2Fcourses%2Fcompsci773s1c%2Flectures%2FImageProcessing-html%2Ffourier.html;256;256
Another example:
https://www.google.dk/search?q=image+fourier+transform&biw=1366&bih=635&source=lnms&tbm=isch&sa=X&ei=gMczVcfkB6X4ywPA-oDoBg&ved=0CAYQ_AUoAQ#imgrc=jBPutaInISXgpM%3A;onXRsGUbsuGlPM;http%3A%2F%2Fwww.athoughtabroad.com%2Fimages%2F14.png;http%3A%2F%2Fwww.athoughtabroad.com%2F2011%2F10%2F22%2Fa-connection-between-motion-blur-and-the-fourier-transform;500;325
More ingenious use of fourier-transform: Say you have a photo (A) of a car passing by. As you have used a long shutter-time the photo has been blurred, so you cannot read the registry-number. But maybe you can spot a stretched reflection on the car, and thereby determine the exact length and direction of the blur. You now draw a picture (B) of a dot, and draw picture (C) of a line (blurred dot) with the same length and direction as the blurred reflection. Fourier-transform A, B, C into Af, Bf, Cf. Then you calculate: Df = Af*Bf/Cf, and calculate D = inverse fourier-transform of Df. You can now read the registration-number in D.
I don't know what a local phase is.
Likes ramdas
Thanks to all. But again i am disturbing you. If i want to find phase at each frequency or coordinate of image , mathematically what should i do ?
FAQ: Physically what is phase of an Image?
What is the physical meaning of phase in an image?
The phase of an image refers to the distribution of light intensity and wavelength in a particular area of the image. It is a measure of the spatial variation of the wavefront of light that has passed through the object being imaged.
How is phase information captured in an image?
The phase information in an image is captured through interferometric techniques, such as holography or phase contrast microscopy. These techniques use the interference patterns between the object wave and a reference wave to capture the phase information.
What is the importance of phase in image analysis?
The phase information in an image is important as it can reveal details about the physical properties of the object being imaged, such as its thickness, refractive index, and surface structure. It also allows for the visualization of transparent or low-contrast objects that cannot be seen with traditional intensity-based imaging.
Can phase information be extracted from a traditional intensity-based image?
Yes, it is possible to extract phase information from a traditional intensity-based image using computational methods such as phase retrieval algorithms. These algorithms use numerical techniques to reconstruct the phase information from the intensity data.
How does phase contribute to 3D imaging?
Phase information plays a crucial role in 3D imaging as it allows for the reconstruction of the shape and depth of an object. By capturing the phase information from multiple angles, 3D images can be created, providing a more comprehensive understanding of the object's structure and properties.
