Physics 1 Parabolic Motion Question Confusion
In summary, the discussion revolves around the confusion some students experience with parabolic motion questions in physics, particularly in understanding the principles of projectile motion, the role of gravity, and the equations of motion involved. The complexity arises from interpreting the parameters and applying the correct formulas, leading to difficulties in solving problems accurately.
Confused_Student33
Thread moved from the technical forums to the schoolwork forums
Problem: A small forest animal jumps with an initial speed of v0 = 15.0m/s and travels to a maximum height of 2.160m. What horizontal distance would the animal travel if the launch angle is i) 45.0 degrees or ii) 42.0 degrees?
Correct Answer: i) 24.95m ii) 25.02m
My professor solved this by: Change in y = 0 - 2.16m
-2.16m = (15Sin45)t + .5gt^2 ----- Use Quadratic to solve for t
R = (15Cos45)t ----- Plug in t to solve for range
I'm confused on why he used Viy = 2.160m
My understanding is that this animal initially jumped from an unknown height to 2.16m. Shouldn't Viy be the unknown height instead of 2.16m? Since he is using 2.16m as a starting point, is the distance the animal traveled before it reaches 2.16m ignored? Wouldn't using 2.16m as a starting point also ignore the time it took before he reached his max height?
Hi, and
:welcome:
How high does one jump if starting (straight up) from zero with a speed of 15 m/s ?
Likes Confused_Student33
You can assume the given height is measured from the jumping point. What is unknown is the angle.
I don't see that in your scenario ??
Strange. If the initial speed is ##v_0 = 15## m/s, and the initial angle is 45 degrees, I would expect a total time in the air to follow from ##v_0 \sin({\pi\over 4})\, t -{1\over 2} g t^2 = 0 ## and the horizontal distance travelled from
##x = v_0\cos ({\pi\over 4})\, t##
Ah, there seems to be something going wrong here. The
suggests a much greater height is reached than the 2.16 m in the story.
And that 42 degrees should give a longer jump than 45 degrees is something I don't understand either.
To get the given answers, interpret it thus:
Edit: correction…
The 2.16m is not the max height of the jump, it is the landing height below the starting point in both cases. I.e. the height gain is -2.16m.
The range is maximised when ##2\sin^2(\theta)=\frac 1{1-hg/v^2}##, about 42.5° here.
g is 9.8m/s^2, not 9.81.
Likes BvU and Confused_Student33
And you get 24.95 for the ##45^o## angle?
Assuming that it land on the way down, I get 28.1 m.
It could also land there on the way up and then the horizontal range is just 3.3 m.
See my correction.
What correction?
nasu said:
What correction?
Originally it read as though the 2.16m was above the launch point.
No animal can jump anything like that distance! Especially small forest animals.
Well, it could if it takes off at 15m/s (running start?) and the landing point is 2m below launch (which is what the question has to mean to get this answer, though I suspect that is just a sign error in the solution).
It's jumping out of tree, perhaps? It would need to avoid all the other trees within a 25m radius.
It could be a flying fox, but then the motion is not parabolic.
So the consensus here is that the formulation of the problem should have been
"A small forest animal jumps with an initial speed of v0 = 15.0m/s and travels to a maximum drops by height of 2.160m. What horizontal distance would the animal travel if the launch angle is i) 45.0 degrees or ii) 42.0 degrees?"
That is the formulation that the professor solved, not the formulation that matches the statement of the problem. I think the correct course of action is for OP to ask the professor "In what sense does the animal travel to a maximum height of 2.160 m if its height drops by 2.160 m at the end of the jump?"
If we go along with the professor's professed solution, we will be complicit to confusing @Confused_Student33 even more. Given OP's experience with this problem, how do you think OP will interpret "maximum height" in the future?
That was my rant of the day.
Likes MatinSAR, berkeman, Confused_Student33 and 3 others
Thank you for the input! I think he forgot to double the time in his answer lol. He allowed corrections and I got full credit back doing it his way, but I'll ask him in his office hours and let yall know what he says.
Likes kuruman and berkeman
Great! I am curious to see what he says.
Likes MatinSAR
FAQ: Physics 1 Parabolic Motion Question Confusion
What is parabolic motion in physics?
Parabolic motion refers to the trajectory of an object that is thrown or projected into the air and moves under the influence of gravity, following a curved path that can be described by a parabola. This type of motion is common in projectile motion problems where an object is given an initial velocity at an angle to the horizontal.
How do you derive the equations of motion for a projectile?
To derive the equations of motion for a projectile, you start with the initial velocity components: \( v_{0x} = v_0 \cos(\theta) \) and \( v_{0y} = v_0 \sin(\theta) \). Using these, the horizontal and vertical positions as functions of time are given by \( x(t) = v_{0x} t \) and \( y(t) = v_{0y} t - \frac{1}{2} g t^2 \), where \( g \) is the acceleration due to gravity. These equations describe the parabolic trajectory.
What factors affect the range of a projectile?
The range of a projectile is affected by the initial velocity, the angle of projection, and the acceleration due to gravity. The optimal angle for maximum range in a vacuum is 45 degrees. Air resistance can also affect the range, but it is often neglected in basic physics problems.
How do you calculate the time of flight for a projectile?
The time of flight for a projectile can be calculated by analyzing the vertical motion. The time to reach the maximum height is \( t_{up} = \frac{v_{0y}}{g} \). The total time of flight is twice this value, as the time to ascend is equal to the time to descend, giving \( t_{total} = \frac{2 v_{0y}}{g} \).
Why is the horizontal velocity constant in projectile motion?
The horizontal velocity of a projectile is constant because there are no horizontal forces acting on the object (assuming air resistance is negligible). The only force acting on the projectile is gravity, which affects only the vertical component of the motion, causing the vertical velocity to change while the horizontal velocity remains unchanged.
