MHB Physics: AM Radio Station Emits Photons/sec at 1000-kHz
An 84-kW AM radio station broadcasting at 1000 kHz emits photons at a specific rate determined by the energy of each photon. The energy of a single photon at this frequency is calculated using Planck's constant, resulting in approximately 6.626 x 10^-28 Joules. Given the station's power output of 84,000 Joules per second, the number of photons emitted each second can be determined using the formula N = Es / Eν. This calculation reveals the significant number of photons transmitted by the antenna. The discussion effectively illustrates the relationship between radio frequency, photon energy, and emission rates.
yakin
Physics: An 84-kW AM radio station broadcasts at 1000-kHz. How many photons are emitted each second by the transmitting antenna? (h=6.626E-32 Js)
Mathematics news on Phys.org
Energy of a single photon with frequency $$\nu$$ is:
$$E_{\nu}=h \nu$$
where $$h$$ Plank's constant.
So for our 1000 kHz signal the energy of a single photon is:
$$E_{\nu}=h \nu= 6.626\times 10^{-32} \times 1000 \times 1000= 6.626\times 10^{-28}$$ J
The radio station is emitting $$E_s=8.4\times 10^4$$ Joules per second, so the number of photons emited per second is:
$$N=\frac{E_s}{E_{\nu}}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
