Crazymechanic
- 831
- 12
Ok so I'm reading up on quantum computers , and I want to ask some question to clear some things up.
So in simple terms a quantum computer or the chip itself would have to be made of something , a enclosure somekind that can hold single particles seperated, that have spins (most common probably electrons or protons ) , I guess the more confined particles a computer could have the better , so far so good.I also understand that each of these separated particles have to be kept in a confined area otherwise they might just crash into the container wall or whatever comes close , so their probably held up or would have to be held in place by the help of one of the fields those particles interact with like electric or magnetic.
Now I hear and read about the cryogenic , freezing stuff also involved in the physical devices of experiments so I ahve my first question if a field could keep the particle confined and not to touch or crash into anything wouldn't that be enough , I guess there is a reason for that cooling , is it because when you cool them (the particles) down their " jiggling" or random movement also drops and that is necessary in order to determine the state in which they are in ?
The last question leads to my next one , if those particles have to be confined and they cannot touch anything as that would cause decoherence at best and any interaction (physical) would probably loose the state in whic the particle is in then by what method can the computer tell or sense the particles state to make the computations based on that if you can't just probe the particle or do any other interaction with it?
a ordinary cpu has millions of transistors which pass physical voltage (signal) through them , but how does one " attach a wire" to specially confined single particle to tell it's state, I guess I'm missing something here as the method must involve something that I'm not aware of.
anyways those are the questions as of now , thank you for answers:)
