Physics C - Rotational motion/forces
In summary, the conversation discusses a scenario where a rider stands in a rotating cylinder and does not slide down the wall despite the floor lowering. The calculations involve the rider's mass, the radius and speed of the cylinder, and the coefficient of static friction. The force preventing the rider from falling is likely the frictional force, and a person of 100 kg would not slide down the wall at the same rotational speed.
dominus96
51
An amusement park ride consists of a rotating cylinder with rough canvas walls. The rider enters the cylinder and stands on the floor as the cylinder starts spinning, and as it spins, the floor lowers but the rider stays against the wall and does not slide down with it. The mass of the rider is 50 kg, the radius of the cylinder is 5 meters, the rotational speed is 2 radians/second, and the coefficient of static friction is 0.6.
a) Calculate the upward force that allows the rider from falling when the floor lowers, and state what provides that force.
b) At the same rotational speed, would a person of 100 kg slide down the wall? Explain.
F=ma
Fcentripetal = mv2/r
I drew a free-body diagram and got 500 N for weight, which would mean 500 N for friction since they are in opposite directions and the rider is in equilibrium. The normal force is 833 N.
For part a) I think the answer is the frictional force, but I don't know the exact reason.
Part b) I would assume that it won't affect it. Am I right?
bump can someone help me?
Hello! As a physicist, I can provide a response to your question regarding rotational motion and forces.
For part a), you are correct in stating that the upward force preventing the rider from falling is the frictional force. This is because as the cylinder rotates, the rider experiences a centripetal force pulling them towards the center of the cylinder. This force is balanced by the frictional force acting in the opposite direction, providing the necessary centripetal force to keep the rider in equilibrium and prevent them from sliding down the wall.
For part b), the mass of the rider does not affect the frictional force in this situation. This is because the frictional force depends on the coefficient of static friction and the normal force, both of which remain constant regardless of the rider's mass. Therefore, a person of 100 kg would also not slide down the wall, as long as the coefficient of static friction and the rotational speed remain the same.
I hope this helps clarify your understanding of rotational motion and forces in this scenario. Keep up the good work in your studies of physics!
FAQ: Physics C - Rotational motion/forces
What is rotational motion in physics?
Rotational motion in physics is the movement of an object around a fixed axis. It involves both translation, which is the movement of an object in a straight line, and rotation, which is the movement of an object around an axis.
What is the difference between linear and angular velocity?
Linear velocity is the rate of change of an object's position in a straight line, while angular velocity is the rate of change of an object's angular position around an axis. Linear velocity is measured in meters per second (m/s) while angular velocity is measured in radians per second (rad/s).
How does rotational inertia affect an object's motion?
Rotational inertia, also known as moment of inertia, is the resistance of an object to changes in its rotational motion. Objects with a larger rotational inertia require more torque to change their rotational speed, while objects with a smaller rotational inertia can rotate more easily.
How do we calculate torque in rotational motion?
Torque in rotational motion is calculated by multiplying the force applied to an object by the distance from the axis of rotation. The direction of the torque is perpendicular to both the applied force and the distance from the axis of rotation.
What is the relationship between torque and angular acceleration?
According to Newton's Second Law for rotational motion, the net torque acting on an object is equal to the moment of inertia multiplied by the angular acceleration. This means that the larger the torque applied to an object, the greater its angular acceleration will be.
