Physics Calculating Distance and Direction
In summary: Right. If you still don't get what you did wrong in post #7, think about what exactly the (x,y) you calculated means... it is the vector that takes the diver from where to where?
Anonymous1135
A diver explores a shallow reef off the coast of Belize.
She initially swims 90.0 m north, makes a turn to the east
and continues for 200.0 m, then follows a big grouper for
80.0 m in the direction 30° north of east. In the meantime,
a local current displaces her by 150.0 m south. Assuming
Chapter 2 | Vectors 101
the current is no longer present, in what direction and how
far should she now swim to come back to the point where
she started?
Answer is 240.2m and 2.2° South of West
Ok so in my attempt I got
90.0m N ----------------------------- 90cos90 = 0 90sin0=90
200.0m E -----------------------------200cos200=200 200sin0=0
80.0m 30° North of East------------ 80cos30 = 69.28 80sin30=40
150m S ---------------------------------150cos270=0 150sin270=150
so 269.28i - 20 j
sqrt 269.28^2+20^2 = 270.02 in the direction 4.24° South of North Ive done this problem several time same result I have an idea where the issue is. Any help would be appreciated. This is not a homework question I am just doing some problem to get a head when spring semester starts
Go through each step and make sure you are using the correct angle in your computations and add the correct components.
I suggest you write down the vector you get on the form xi+yj in each step. It will make it easier to read your post.
Anonymous1135 said:
South of North
There is no such thing in terms of bearings. Do you understand how the ”x of y” designation works?
Sorry, typo I didn't mean South of North I mean South of East since the x component is positive and and the y component is negative which make its in the 4th quadrant
I though my component were correct
90.0m N ----------------------------- 90cos90 = 0 90sin0=90-----------(0i + 90j)
200.0m E -----------------------------200cos200=200 200sin0=-------(200i + 0j)
80.0m 30° North of East---------- 80cos30 = 69.28 80sin30=40---(69.28i + 40j)
150m S --------------------------------150cos270=0 150sin270=150--(0i - 150j)
Are you sure this does not say east of north?
This is how its wording from the book
If Calculated as East of North I get the answer 240.17 but the direction now it 2.2 North of East
Then it is a typo.
Which vector is directed 2.2° North of East and what does the question ask you for?
Orodruin said:
Then it is a typo.Which vector is directed 2.2° North of East and what does the question ask you for?
Well the way I came up with 2.2° north of east was adding the xy which gave me 240i+9.28j which puts it in the first quadrant and arctan ( 9.28/240) = 2.2°
This does not answer the question I asked you. Please answer the question in #6 completely.
Not sure what you mean by which vector is directed 2.2° North of East and the question ask me which direction and how far she has to swim back to her starting point.
With the regard to the diver's course, what point does that (x,y) represent and with respect to what point as origin? As a vector representing a net movement, what movement?
Sorry I don't follow
You calculated the x and y coordinates of some point. What point? Answer this in terms of the diver's journey.
Those coordinates only mean anything relative to an origin. What point is your origin? Again, identify the point in the diver's journey, not just "(0,0)".
Indeed, but this is not what you have computed.
Let me ask you this without vectors, just one dimension. I walk 30 m to the right. How far and in what direction do I have to walk to get back to where I started?
You would walk back 30m to the left to get to where you started
Right. If you still don't get what you did wrong in post #7, think about what exactly the (x,y) you calculated means... it is the vector that takes the diver from where to where? Or try to answer my questions in post #12.
Related to Physics Calculating Distance and Direction
1. How do you calculate the distance between two points using physics?
In physics, the distance between two points is calculated using the distance formula: d = √[(x2-x1)^2 + (y2-y1)^2]. This formula takes into account the x and y coordinates of the two points and uses the Pythagorean theorem to calculate the distance between them.
2. What is the difference between distance and displacement in physics?
In physics, distance refers to the actual length of the path between two points, while displacement refers to the straight-line distance between the starting and ending points. Distance is a scalar quantity, meaning it has only magnitude, while displacement is a vector quantity, meaning it has both magnitude and direction.
3. How do you calculate direction using physics?
In physics, direction is typically represented using angles or vectors. To find the direction between two points, you can use trigonometric functions such as sine, cosine, and tangent to calculate the angle between the line connecting the two points and a reference axis. Alternatively, you can use vector addition to find the direction and magnitude of a vector pointing from one point to another.
4. What is the difference between speed and velocity in physics?
In physics, speed refers to the rate at which an object covers distance, while velocity refers to the rate at which an object changes its position. Speed is a scalar quantity, meaning it has only magnitude, while velocity is a vector quantity, meaning it has both magnitude and direction. This means that an object can have a constant speed but changing velocity if it changes direction.
5. How do you use physics to calculate the time it takes to travel a certain distance?
In physics, time is typically calculated using the equation t = d/v, where t is time, d is distance, and v is velocity. This formula can also be rearranged to solve for distance or velocity, depending on which values are known. Additionally, if the object is accelerating, the equation t = √(2d/a) can be used, where a is acceleration.
41K
