Physics Case: Electric Charges and Forces.
In summary, electric charges are a fundamental property of matter that can be positive or negative and cause electromagnetic interactions. They are measured in units of coulombs and can be measured using an electrometer. There is a difference between static and current electricity, with static being a build-up and current being a flow of charges. The force between two charged objects is affected by the distance between them according to Coulomb's Law. There are different types of electric forces, including attractive, repulsive, gravitational, and magnetic forces.
Firu
Four punctual charges are located as shown in the figure below. A, B, and C are located at the vertices of an equilateral triangle. The values for these charges are A = +1.4microculombs, B = 4.5microculombs, C = -6.7microculombs and D = +7.1microculboms. THe length of the triagnle's base is shown in the figure. Calculate the net force experienced by charge D (magnitude and direction from the X - Axis). D is on the center of the triangle.
--------------A-----------------------------D---------------------C-------------B---------
Distance between C -B = 7.1nm
F= K*q1*q2/R^2
Converted charges to culombs, so i got
A = 1.4x10^-5
B = 4.5x10^-5
C = -6.7x10^-5
Then converted the distance to meters so got:
7.8x10^-8
Used equilateral triangle rules to get the distance between A - D, B - D, and C -D (which is the same) and got R = 4.5x10-8.
K = 9x10^9.
Used the F formula on each pair (A -D, B -D, C - D) using
F = k*q1*q1/R^2.
On every formula q1 = D (7.1x10^-5) and q2 was A, B or C.
R^2 is: 2.025x10-15.
Forces I got were.
A - D = 4.41x10^15 = F1
B - D = 1.42x10^16 = F2
C - D = -2.1x10^16 = F3
Net force =
F1+F2+F3
Net Force = -2.39x10^15.
Moving towards C according to the diagram.
Is this correct?
Thanks.
Yes, your solution is correct. The net force experienced by charge D is -2.39x10^15 N, directed towards C.
Related to Physics Case: Electric Charges and Forces.
1. What is an electric charge?
An electric charge is a fundamental property of matter that causes it to experience electromagnetic interactions with other charged particles. Electric charges can be positive or negative, and like charges repel each other while opposite charges attract.
2. How are electric charges measured?
Electric charges are measured in units of coulombs (C). One coulomb is equivalent to the charge of 6.24 x 10^18 electrons. Charges can also be measured using a device called an electrometer, which measures the difference in potential energy between two points in an electric field.
3. What is the difference between static and current electricity?
Static electricity refers to the build-up of electric charges on the surface of an object, while current electricity refers to the flow of charges through a conductor. Static electricity is typically caused by friction or contact between two objects, while current electricity is produced by a continuous flow of electrons.
4. How does the distance between two charged objects affect the force between them?
The force between two charged objects is directly proportional to the product of their charges and inversely proportional to the square of the distance between them. This relationship is described by Coulomb's Law, which states that the force between two charges (F) is equal to the product of the charges (q1 and q2) divided by the square of the distance (r) between them, multiplied by a constant (k). In mathematical terms, it can be written as F = k * (q1 * q2) / r^2.
5. What are the different types of electric forces?
The two main types of electric forces are attractive and repulsive. Attractive forces occur between opposite charges, while repulsive forces occur between like charges. Other types of electric forces include gravitational forces (between charged objects and neutral objects) and magnetic forces (between moving charged particles).
11K
