Physics Challenge I: The Raindrop solved by mfb and voko
In summary, we assume a cloud of tiny water droplets suspended in air with a negligible effect of gravity on the droplets. A raindrop falls through the cloud, initially with negligible size, and as it falls, the water droplets it hits are added to its volume. The raindrop is assumed to be spherical at all times. We can calculate the acceleration of the raindrop by considering the rate of water collection and using equations for volume and velocity. The final equation for acceleration includes both gravity and the raindrop's velocity. We also discuss the validity of assuming the volume swept out by the cross section of the raindrop and the volume swept out by the boundary of the lower hemisphere are equivalent when calculating the mass gained
  • #36
Forgetting all physics and merely focusing on mathematics, the problem is this ODE:
[tex]
\left(\begin{array}{c}
\dot{x}_1(t) \\ \dot{x}_2(t) \\
\end{array}\right)
= \left(\begin{array}{c}
\alpha - \beta\frac{x_1(t)^2}{x_2(t)} \\ \gamma x_1(t) \\
\end{array}\right)
[/tex]
Considering the style in which voko solved the stuff, I think there's is a signifigant chance that a nice formula for all solutions doesn't necessarily exist. However, it could be that a formula exists for a graph of the solutions. That means that we don't seek a mapping [itex]t\mapsto (x_1(t),x_2(t))[/itex], but instead a mapping [itex]x_1\mapsto \mathcal{X}_2(x_1)[/itex] such that the solution is of the form [itex]t\mapsto (x_1(t),\mathcal{X}_2(x_1(t)))[/itex]. This lead me to the one component first order ODE
[tex]
f'(x) = \frac{Cxf(x)}{Af(x)-Bx^2}
[/tex]
which seems like some progress, but still was too difficult for me to solve in a moment.
Mathematics news on Phys.org
  • #37
Initial value [itex]f(0)=0[/itex] has a simple solution
[tex]
f(x) = \frac{2B+C}{2A} x^2
[/tex]
hm.. what are the rest?
  • #38
I assumed
[tex]
f(x) = a_0 + a_1x + a_2x^2 + a_3x^3 +\cdots
[/tex]
with [itex]a_0\neq 0[/itex] and got
[tex]
f(x) = a_0 + \frac{C}{2A}x^2 + \frac{BC}{4A^2a_0}x^4 + \frac{BC}{6A^3a_0^2}\Big(B-\frac{C}{2}\Big)x^6 + \cdots
[/tex]
Doesn't look recognizable.
Altought this seems to hint that there could exist a function [itex]x\mapsto G_{B,C}(x)[/itex] such that
[tex]
f(x) = f(0) + f(0)G_{B,C}\Big(\frac{x^2}{Af(0)}\Big)
[/tex]
  • #39
The attempt
[tex]
f(x) = \frac{2B+C}{2A}x^2 + g(x)
[/tex]
works if [itex]g[/itex] satisfies the DE
[tex]
g'(x) = -\frac{2Bxg(x)}{Ag(x) + \frac{C}{2}x^2}
[/tex]
which is similar to the original DE for [itex]f[/itex], but with some key differences. If we assume that the constants are positive, the new DE has property [itex]g(x)>0\implies g'(x)<0[/itex] for all [itex]x>0[/itex]. So it seems reasonable that [itex]g[/itex] will probably approach zero if it starts at some positive value. With very large [itex]x[/itex] approximation
[tex]
g'(x) \approx -\frac{4B}{Cx}g(x)
[/tex]
should hold, which implies that there is signifigant chance for the approximation
[tex]
g(x) = D x^{-\frac{4B}{C}} + o(?)\quad\quad\quad\textrm{when}\;x\to\infty
[/tex]
with some constant [itex]D[/itex] and with some small error term.
  • #40
In thread how to prove asymptotic properties I finally managed to give a rigorous proof that the solutions for [itex]f[/itex] with all initial values [itex]f(0)>0[/itex] will have the form
[tex]
f(x) = \frac{2B+C}{2A}x^2 + O\Big(x^{-\frac{4B}{C}+\epsilon}\Big)
[/tex]
in the limit [itex]x\to\infty[/itex].
  • #41
I believe that the solution which won this challenge contains a mistake. The rate of mass increase does not obey a formula
[tex]
\dot{m}(t) = \pi\rho r(t)^2v(t)
[/tex]as is believed by everyone, but instead a formula
[tex]
\dot{m}(t) = \pi\rho r(t)^2\big(v(t)+2\dot{r}(t)\big)
[/tex]
which follows by taking into account the way in which the lower boundary of the water drop moves downwards due to the increase in the drop size.
  • #42
That's the approximation which has been discussed several times now.
  • #43
Most comments seem to imply that the contribution from increase in size would be so small that the final differential equation (which was used in solution) would be correct. As if the correction was of infinitesimal order [itex]dt^2[/itex] or something like that. Also, the discussion must have been insufficient, since the correct differential equation has not been mentioned.
I checked that with the correct differential equation the result is still the same, that acceleration converges to [itex]\frac{g}{7}[/itex]. A result, which should be seen as interesting.
  • #44
A different problem: (Heavily related to the original challenge.)
A free planet moves with constant velocity in space. Then it encounters a massive cloud of dust, which it starts to absorb to itself on its path. The question is what happens. This could be slightly easier than the accelerating water drop actually, but it's still not trivial.
It's obvious that the planet will slow down and increase in size. But for example, it is not obvious at all if it will come to halt at some point (converge to some point), or continue infinitely far with always slower speeds.
I solved this (or I believe I did), and I proved that the velocity will slow down with rate [itex]v\sim t^{-\frac{3}{4}}[/itex]. Therefore the traveled distance will be [itex]\sim t^{\frac{1}{4}}[/itex], and the planet will not stop due to the cloud.
  • #45
For a planet, gravity would certainly be relevant. What was wrong with the raindrop (we can do the experiment at the ISS)?
  • #46
Yes to be precise we should take into account how the planet affects the dust cloud, but then on the other hand, we also should take into account the air resistance with the water drop, so this is merely mathematics anyway, and these are interesting math problems.
Also, it might seem strange to not make the approximation [itex]v+2\dot{r}\approx v[/itex] considering that we are making other approximations anyway. Still it would be preferrable that we know what approximations we are making. One point of view is that we should make approximations only if they make the calculations essentially easier. Keeping [itex]v+2\dot{r}[/itex] doesn't lead to much added difficulty in the end.
  • #47
[tex]
\end{array}\right)
\end{array}\right)
[/tex]
I just understood that this choice was a mistake. The attempt must be to find a mapping [itex]x_2\mapsto\mathcal{X}_1(x_2)[/itex] such that the solution is of the form [itex]t\mapsto (\mathcal{X}_1(x_2(t)),x_2(t))[/itex]. This way the we end up with the same formulas that were in voko's post.
18K
