Physics experiment on water and magnet
In summary, for a research paper on physics, the student plans to drop a powerful magnet onto water and measure the height of the water 'jump' as a reaction force. The best variable to use for this experiment would be varying the speed of the magnet when it is dropped onto the water.
cibui
So, i am supposed to do research paper on whatever topic of around 4000 words. So, i chose physics as my subject of interest. So, for my research i want to do an experiment which i will be dropping a small but powerful magnet on water and measure the height of the water which 'jumps' up due to reaction force when the magnet hits the water.
So, i am still thinking what variable should i use for the experiment? i can vary the temperature of the water, or pass through electric current to the water or etc. So, what do you think would be the best variable can i use in order to get a nice graph to plot and can be analysed on? Suggestions are much appreciated..
Thanks
for the help. I think varying the speed of the magnet when it is dropped onto the water would be the best variable that I can use. That way, I can measure the height of the water that 'jumps' up as I drop the magnet onto it at different speeds and plot a graph to analyse.
FAQ: Physics experiment on water and magnet
How does a magnet affect water?
A magnet does not have any direct effect on water. However, it can indirectly affect the properties of water by creating a magnetic field that can interact with the ions and molecules present in water.
Can a magnet purify water?
No, a magnet cannot purify water. Water purification involves removing impurities such as bacteria and pollutants, which cannot be achieved by using a magnet.
What happens when a magnet is placed near water?
When a magnet is placed near water, it creates a magnetic field that can cause the molecules in water to align in a certain way. This can change the properties of water, such as its surface tension and boiling point.
Can a magnet make water levitate?
No, a magnet cannot make water levitate. This is because the magnetic force of a magnet is not strong enough to counteract the force of gravity on water.
What is the purpose of conducting a physics experiment on water and magnet?
The purpose of conducting a physics experiment on water and magnet is to understand the effects of magnetism on the properties of water, and to explore potential applications of this phenomenon in areas such as water treatment and purification.
