Physics < Force of Gravity > HELP?
In summary, a wrench fell from a hovering helicopter during construction of the Canada pavilion in Vancouver. It took 9.0 seconds to reach the ground and the distance was 400 meters. There seems to be some confusion about finding the velocity and height, with suggestions of using vavg or the formula y=ut+0.5at2. It is also mentioned that the initial velocity is zero. The question remains, what would be wrong with using the formula d=v/t in this scenario?
McKeavey
30
During construction of the Canada pavilion in Vancouver, a wrench fell out of a hovering helicopter and took 9.0 s to reach the ground.
How far was the helicopter from the ground?
I'd assume you find Vavg.
And put it into d = v/t
But when I do that I end up with d = 4.9.
The answer says it's 4.0 x 10^2 m AKA 400m.
What did I do wrong?
And there's no additional information given from the Q.
You know that y=ut+0.5at2.
Assume the initial velocity is zero.
You are given time, what is the height y?
Oh..
What would be wrong with using d = v/t though? :eek:
McKeavey said:
Oh..
How you plan to go about finding 'v'?
It seems like you have the right approach in calculating the distance using the formula d = v/t. However, the missing piece of information is the initial velocity of the wrench. Without that, it is not possible to accurately calculate the distance.
Additionally, it is important to note that the acceleration of the wrench due to gravity is not a constant 9.8 m/s^2, as it is affected by air resistance and other factors. So, even with the initial velocity, the calculated distance may not be entirely accurate.
In order to accurately determine the distance, we would need to know the initial velocity and also take into account any other factors that may affect the acceleration of the wrench. Without that information, it is not possible to determine the exact distance the helicopter was from the ground.
Related to Physics < Force of Gravity > HELP?
1. What is the force of gravity?
The force of gravity is a natural phenomenon by which all objects with mass are brought towards each other. It is commonly described as the force that pulls objects towards the center of the Earth.
2. How is the force of gravity calculated?
The force of gravity is calculated using Newton's Law of Universal Gravitation, which states that the force of gravity is directly proportional to the masses of the two objects and inversely proportional to the square of the distance between them.
3. What is the relationship between mass and the force of gravity?
The force of gravity is directly proportional to the mass of an object. This means that the greater the mass of an object, the greater the force of gravity it exerts.
4. How does distance affect the force of gravity?
The force of gravity decreases as the distance between two objects increases. This is because the farther apart two objects are, the weaker the gravitational pull between them.
5. What is the difference between weight and the force of gravity?
Weight is a measure of the force of gravity acting on an object. The force of gravity is a natural phenomenon, while weight is a measurement of that force. Weight can change depending on the strength of the gravitational pull, while the force of gravity remains constant.
9K
