Physics heat problem Using calories.
In summary, the conversation was about calculating the number of calories needed to raise the temperature of a 44 g gold chain from 20°C to 125°C. The solution involved multiplying the mass and temperature change and then also multiplying by the heat capacity of gold. The conversation also mentioned the importance of considering different thermal properties of materials and the need to convert energy from Joules to Calories.
astru025
163
How many calories will it take to raise the temperature of a 44 g gold chain from 20°C to 125°C?
You are trying to raise the temperature of 44 g. of gold by 105 degrees celsius. I tried 44 x 105 but this answer was incorrect.
3. The Attempt at a Solution
The answer is got was 4620 cal. But this was not correct.
You also have to multiply by the heat capacity of gold(solid) to get the number of calories.
Chet
They told you it was gold because different materials have different thermal properties. It takes more energy to heat up 44g of water by 105C then it does to do the same if it's gold, wood, air...
See the table of data for various materials down here..
http://en.wikipedia.org/wiki/Heat_capacity#Table_of_specific_heat_capacities
Note the units. If you use this data you will have to convert the resulting energy from Joules to Calories.
Thank you very much! I came up with the correct answer
I would approach this problem by first understanding the concept of specific heat capacity, which is the amount of heat required to raise the temperature of a substance by 1 degree Celsius per unit mass. In this case, we are dealing with gold, which has a specific heat capacity of 0.129 J/g°C.
Next, I would calculate the amount of heat required to raise the temperature of the gold chain from 20°C to 125°C using the formula Q = m x c x ΔT, where Q is the heat energy, m is the mass, c is the specific heat capacity, and ΔT is the change in temperature.
So, Q = (44 g) x (0.129 J/g°C) x (125°C - 20°C) = 462.48 J.
Since we are using calories as the unit of energy, we need to convert the answer to calories by dividing it by 4.184, which gives us 110.6 cal. Therefore, it would take approximately 110.6 calories to raise the temperature of a 44 g gold chain from 20°C to 125°C.
It is important to note that this calculation does not take into account any external factors such as heat loss to the surroundings, which may affect the actual amount of heat required. However, this is a good estimate and should give us a close approximation of the amount of energy needed to raise the temperature of the gold chain.
Related to Physics heat problem Using calories.
1. What is a calorie in physics?
In physics, a calorie is a unit of energy that is defined as the amount of energy required to raise the temperature of 1 gram of water by 1 degree Celsius.
2. How does heat transfer occur in physics?
Heat transfer in physics occurs through three main mechanisms: conduction, convection, and radiation. Conduction is the transfer of heat through direct contact between two objects, convection is the transfer of heat through the movement of fluids, and radiation is the transfer of heat through electromagnetic waves.
3. What is the specific heat capacity in physics?
The specific heat capacity in physics is the amount of energy required to raise the temperature of 1 gram of a substance by 1 degree Celsius. It is a measure of how much heat a substance can store.
4. How do you calculate heat in physics?
In physics, heat can be calculated using the equation Q = mcΔT, where Q is the amount of heat transferred, m is the mass of the object, c is the specific heat capacity, and ΔT is the change in temperature.
5. What is the difference between heat and temperature in physics?
Heat and temperature are two related but distinct concepts in physics. Heat is a form of energy that is transferred from one object to another due to a difference in temperature. Temperature, on the other hand, is a measure of the average kinetic energy of the particles in a substance. In other words, heat is the transfer of energy, while temperature is a measure of the amount of energy.
