Physics help? Topic: kinetic energy?
In summary, we have a block of mass 10 kg being pulled 5 m upwards along a rough surface at an angle of 20 deg with an external force of 100 N and initial velocity of 1.5 m/s. The coefficient of friction is 0.4. Using the formula Wg = mgsinθ x d, we calculated the work done by gravity to be 167.6 J. For the increase in internal energy between the block and the surface as a result of friction, we need to consider the work done by the friction force. The frictional force is the product of the coefficient of friction and the normal force (N = mg - Fsinθ). The frictional force is 25.
oligosaccharide
A block of mass 10 kg is pulled 5 m upwards along a rough surface at an angle of 20 deg, an external force of 100 N and vi = 1.5 m/s. The coefficient of friction is 0.4. Calculate:
1) The work done by gravity
2) The increase in internal energy between the block and the surface as a result of friction
3) Work done by external force
4) The change in kinetic energy of the block
5) The speed of the block after moving 5 m.
Thanks a lot!
Please show your work first, and then we will be able to guide you.
For 1), I calculated the work done by gravity by musing the formula Fd, so Wg = mgsintheta x d, so Wg = 167.6 J.
I don't know how to do 2)
For 3), I multiplied the external force by cos 20 and then by 5 m = 469.8 J
For 4), the change in kinetic energy equals the work done by external force minus the work done by friction.
The frictional force is the coefficient of friction multiplied by the normal force (N = mg - F sin theta).
So the frictional force is 25.5 N
Change in kinetic energy = 469.8 J - (25.5 x 5) J = 342.4 J
For 5), change in kinetic energy = 1/2 x m(vf^2 - vi^2)
And I got vf = 8.36 m/s
Hello sugar and welcome to PF. Good thing you re-posted with at least something. Next time use the template. Read the guidelines to find out why that's reall really useful.
2) might have something to do with the work the friction force 'does'.
3) Does the external force pull along the slope or does it pull horizontally ? Or vertically ?
4) Not correct. you forget another energy change. And, again, which way is F pulling in your N calculation ?
And: make a drawing !
1) The work done by gravity is given by the equation W = mgh, where m is the mass of the block, g is the acceleration due to gravity, and h is the height the block is pulled. In this case, the block is pulled upwards by 5 m, so the work done by gravity is (10 kg)(9.8 m/s^2)(5 m) = 490 J.
2) The increase in internal energy between the block and the surface as a result of friction can be calculated using the equation W = µNΔx, where µ is the coefficient of friction, N is the normal force, and Δx is the distance the block moves. The normal force is equal to the weight of the block, which is (10 kg)(9.8 m/s^2) = 98 N. So, the increase in internal energy is (0.4)(98 N)(5 m) = 196 J.
3) The work done by the external force is given by the equation W = FΔx, where F is the external force and Δx is the distance the block moves. In this case, the external force is 100 N and the block moves 5 m, so the work done by the external force is (100 N)(5 m) = 500 J.
4) The change in kinetic energy of the block can be calculated using the equation ΔKE = ½mvf^2 - ½mvi^2, where m is the mass of the block, vf is the final velocity, and vi is the initial velocity. In this case, the mass is 10 kg, the initial velocity is 1.5 m/s, and the final velocity can be found using the equation vf^2 = vi^2 + 2aΔx, where a is the acceleration of the block. The acceleration can be found using Newton's second law, Fnet = ma, where Fnet is the net force acting on the block. In this case, the net force is equal to the external force minus the force of friction, so Fnet = (100 N - 0.4(98 N)) = 60.8 N. Therefore, the acceleration is a = (60.8 N)/(10 kg) = 6.08 m/s^2. Plugging in these values, we get ΔKE = ½(10 kg)(vf^
Related to Physics help? Topic: kinetic energy?
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a scalar quantity and is defined as one-half of the mass of an object multiplied by the square of its velocity.
What is the formula for calculating kinetic energy?
The formula for kinetic energy is KE = 1/2 * m * v2, where KE is kinetic energy, m is the mass of the object, and v is the velocity of the object.
How is kinetic energy related to potential energy?
Kinetic energy and potential energy are two forms of mechanical energy. Kinetic energy is the energy of motion, while potential energy is the energy an object has due to its position or state. In some cases, potential energy can be converted into kinetic energy and vice versa.
What are some real-life examples of kinetic energy?
Examples of kinetic energy can be seen in everyday life, such as a moving car, a swinging pendulum, a rolling ball, or a person running. Other examples include a moving train, a spinning top, and wind blowing through a fan.
How does mass and velocity affect the amount of kinetic energy an object has?
The amount of kinetic energy an object has is directly proportional to its mass and the square of its velocity. This means that as mass or velocity increases, so does the kinetic energy of the object. For example, a heavier object moving at a faster velocity will have more kinetic energy than a lighter object moving at a slower velocity.
