Physics homework: acceleration, velocity and speed. help please
In summary, the conversation is about a physics assignment and the answers to various questions related to acceleration, velocity, and gravity. The participants discuss the correct calculations for certain problems and provide explanations for their answers. They also address any doubts or uncertainties about the equations used and provide helpful tips for solving similar problems.
kirsten_2009
137
Warning! Posting template must be used for homework questions; One question per thread.
Hello everyone,
I have this physics assignment to do and I would sure appreciate your guy's input. My attempts to answer the questions are below. Could you please let me know if I'm correct or if I'm wrong or missing anything? Thanks a lot in advance!
1. When you drive a car, might you depress the accelerator pedal without actually accelerating? Could you accelerate without having your foot on the accelerator? Explain.
No. If you press the accelerator then you are increasing the speed which affects velocity and thus you cannot affect velocity without causing acceleration.
Yes. By not pressing on the accelerator; you would assume that the car would slow down if going up a hill, or going on a flat surface (due to friction, gravity and air resistance) or speed up if going downhill and so a change in speed would occur, which would change the velocity, which in turn, would change the acceleration.
2. You drop a rock down a well and hear a splash 3 s later. How deep is the well assuming that air resistance is negligible and the time needed for sound to travel up the well is also negligible?
1/2 (9.8 m/s^2) x 3s^2 = 44.1m ***On a side note, why is there a 1/2 in front of gravity constant?
3. One car goes from 0 to 30 km/h. Later another car goes from 0 to 60 km/h. Can you say which car had greater acceleration? Explain.
I'm tempted to say that the 60km/h car underwent greater acceleration but I'm also tempted to say that you can't really tell because I don't know how long it took these cars to get to the speed they did. Could it not be the case that they accelerated at the same rate but one stopped speeding up and the other continued speeding up but at the same rate?
4. The acceleration due to gravity on the Moon is about 1/6 that on Earth. If an object is dropped near the surface of the Moon, how far does it fall in 10 s?
1/2 (1.63 m/s^2) x 10s^2 = 132 m...? Doesn't look right...?
5. Charlie walks 1 km to the football stadium in 30 minutes, then sits and watches the game for 2 hours, then walks 1 km home in 30 minutes. What was Charlie’s average speed while he was gone?
2km/3 hr = 0.67 km/hr
I'll answer with what I am able to.
Number two is correct: 41m
As for number 3, you are correct on your second assumption. Even if you know initial and final velocities, you can't tell its acceleration without knowing the time it took to go from initial to final velocity. If they took the same time to get to their respective final velocities, then the 60km/hr car would have a greater velocity, but you can't say that because you don't know the time.
On number 4, I got 81.5m. I think what you did is this:
1/2(1.63m/s^2 * 10s)^2 = 132m
what shold be done is this:
1/2(1.63m/s^2)(10s)^2 = 81.5m
With this kinematic equation, make sure you are only squaring the time value. You squared the product of acceleration and time.
Likes kirsten_2009
Hi Ritzycat,
Thanks so much for taking the time to help me out. #4 makes sense now!
Anyone have any comments about #1 and/or #5?
#1 is incorrect.
Your two answers contradict each other - if you could slow down going up a hill without pressing the accelerator, then couldn;t you press the accelerator, while going up a hill, to maintain a constant speed?
#2 you should include your reasoning - why pick that calculation?
How did you account for the amount of time the sound took to get back to the top of the well?
Note: displacement is the area under the velocity-time graph - for the falling stone, what shape is the v-t graph?
That should help you understand where the half comes from.
#3 good thinking - without more information, you cannot tell. You need either the distance or the time.
#4 Try to articulate your doubts: why does that not look right to you?
This is the first step to trouble-shooting.
Why did you choose that equation?
How far would an object fall in 10secs on the Earth?
#5 Well done - C was gone for 3 hours and he covered a total distance of 2km.
Bonus points for not converting to m/s. It is usually OK just to say (2/3)kmph - you don't have to convert everything to decimal.
If you do convert to decimal - watch the sig fig matches up.
Likes kirsten_2009
Hello Mr. Bridge,
Thanks a lot for taking a look at my assignment! It absolutely makes sense. I'm looking into the v-t graph for #2 right now.
Lets see - taking positive direction = "down": the stone starts at u=0 and accelerates uniformly to some speed v > 0 in some time t > 0.
So draw your axis. Mark a point on the time axis and label it t. You don't need to know the value of t here, any point so long as it is bigger than zero. Do the same for the velocity axis - mark it v. This is called "sketching" the graph.
Draw a line from (0,0) to (t,v).
Draw a dotted line from (t,v) to (t,0) ... what shape do you see?
What is the formula for the area of that shape?
If it takes time t for the stone to hit the water and time T to hear the sound, then t<T.
... and it takes the sound T-t time to get to the top.
The time T is what you are given, not t.
If the well isn't very deep, then the correction for the time the sound takes will be very small.
Hello Mr. Bridge,
Sorry for my delay. I was swamped with homework; but I did what you suggested and plotted a t-v graph and got a straight line and the area under
the straight line is a triangle. The formula for the area of a triangle is height x base /2 so I guess the 1/2 comes into account for the fact that it's not the area of a rectangle that we're looking for. This leads me to another question though...isn't the relationship between acceleration and time squared? So...shouldn't I be getting a half parabola? Thanks for all your time and help!
-K.
The acceleration is the slope of the graph you just drew - so you can immediately find the relationship between the acceleration, the time, and the final velocity.
You have just worked out a relationship between displacement, time and the final velocity.
Now use these two simultaneous equations to find the relationship between displacement, time, and acceleration.
Consider these two equations:
[tex]D=\frac{V_i + V_f}{2} \cdot t[/tex]and
[tex]V_f = V_i + at[/tex]
Substitute the 2nd equation into the 1st and see what you get...
FAQ: Physics homework: acceleration, velocity and speed. help please
1. What is the difference between acceleration, velocity, and speed?
Acceleration is the rate of change of velocity over time, measured in meters per second squared. Velocity is the rate of change of position over time, measured in meters per second. Speed is the rate of change of distance over time, measured in meters per second.
2. How do you calculate acceleration?
Acceleration can be calculated by dividing the change in velocity by the change in time. The formula for acceleration is a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
3. How do you calculate velocity?
Velocity can be calculated by dividing the change in position by the change in time. The formula for velocity is v = (xf - xi) / t, where v is velocity, xf is final position, xi is initial position, and t is time.
4. What is the difference between average velocity and instantaneous velocity?
Average velocity is the average rate of change of position over a period of time, while instantaneous velocity is the velocity at a specific moment in time. Average velocity is calculated by dividing the change in position by the change in time, while instantaneous velocity is calculated by taking the derivative of position with respect to time.
5. How do acceleration, velocity, and speed relate to each other?
Acceleration is the rate of change of velocity over time, and velocity is the rate of change of position over time. Therefore, acceleration and velocity are directly related. Speed is the absolute value of velocity, so it is also related to acceleration. If an object is accelerating, its speed and/or velocity will change. If an object is moving at a constant speed, its velocity is constant and its acceleration is zero.
