Physics homework help regarding energy and friction
In summary, the conversation discusses the maximum power output and speed achievable by a car of mass 500kg going up a hill with an angle of 11.534 degrees. The energy dissipated by frictional forces and the necessary frictional force are also brought up. The solution involves calculating the vertical velocity, GPE, KE, and frictional forces, and addressing the assumption of constant speed.
Dan_321
The maximum power output of a car of mass 500kg is 75kW. Up a hill of angle 11.534, its maximum (constant) speed achievable with this power is 30m/s.
What is the energy dissipated by frictional forces every second, and what must the frictional force be?
mgh=loss/gain of GPE, KE=(mv^2)/2=Kinetic energy gained/lost
As this is a right angle triangle, we know that 30sin(11.534) will equal the vertical velocity going up (approx 6m/s). From there we know what mgh is: 6m/s*10*500=30000J gained per second. Since GPE-(KE+Frictional forces) must equal 0, 30000-((500*30^2)/2+F) should give F, but it turns out to be negative. How does this work?
The assumption is that the speed is constant. Review the terms in your calculation given that information.
Yes, but surely the vertical velocity is going to be different from the diagonal velocity?
Yes. I agree with your calculation that the vertical velocity is a constant 6 m/s. Now look at your definitions in "relevant equations".
Why, in this context? As @RPinPA notes, there is no change in KE.
Related to Physics homework help regarding energy and friction
What is the definition of energy in physics?
Energy in physics is defined as the ability to do work or cause a change in an object's state. It is a scalar quantity that is measured in joules (J).
What are the different forms of energy in physics?
In physics, energy can exist in various forms such as kinetic, potential, thermal, chemical, nuclear, and electromagnetic energy. These forms can be converted from one to another, but the total energy in a closed system remains constant.
How does friction affect energy in a system?
Friction is a force that opposes the motion of objects in contact with each other. It can convert kinetic energy into thermal energy, causing a decrease in the total energy of the system. This is why friction is often considered to be a form of energy loss in a system.
How can the coefficient of friction be calculated?
The coefficient of friction can be calculated by dividing the force of friction by the normal force. The force of friction can be measured using a spring scale, and the normal force can be calculated by multiplying the mass of the object by the acceleration due to gravity.
What are some real-world examples of energy and friction?
Some real-world examples of energy and friction include a car's brakes converting kinetic energy into thermal energy to slow down, a person rubbing their hands together to generate thermal energy, and a rollercoaster using potential energy to overcome friction and move along the track.
