Physics lab formula question - help please
In summary: T...=-.000020 T2(p)...=6.28M...=1.43x10^-3 Am^2...=.001100 Am^2r...=20mm...=.020mfit parameter A...=0.7090
  • #36
My professor said this as well..What you want to do is to compare your fit (Y = Ax^n, with n=-3) to the theoretical relation (B = (u0/2pi)(M/r^3) ) . Comparing the two formulae can tell you what the fitted parameter "A" represents.
  • #37
I calculated B* from the given formula - the 1/r3 one.
Yes, so the fitted A parameter should give you the experimental value for uoM/2pi.
Was the core of the solenoid "empty" (filled with air), or did it have some material in it?
  • #38
It doesn't say if it was filled or empty...I'm so frustrated
  • #39
Did you see something inside of the core (middle) of the solenoid?
Do not worry it will not influence the processing of your data.
I am just trying to make sense of the results.
  • #40
No nothing?...
  • #41
So there was "air" inside of the core?
That would mean that uo is applicable here.
  • #42
I don't follow? I'm not understanding what my next step is...
  • #43
See my #37 post.
That means you can calculate uo from the fitted A parameter's value.
  • #44
Andre, I think I might have it now. But I need a little more help . This is what I am told. and here are my two new graphs.
You need two separate graphs...one for each side.
With your plot you want to determine u0. What you are doing is assuming u0 is unknown, and then using the data to determine u0. Of course, in reality, the value for u0 is known. Hence, by comparing "your" value for u0 to the known value gives an idea how well your experiment went.
To determine u0 you have B = (u0/2pi)(M/r^3), or rewritten: B = (u0 M/2pi)r^(-3). Another way of writing this would be Y = Ax^(-3), with Y and x being variables. If were to write B = (u0 M/2pi)r^(-3) as Y = Ax^(-3), what value would you ascribe to "A".
I think those look right. Now in your post 37# to find B, I get 12500 which seems off for the magnetic field. So how do I get B now to solve for the experimental Mu? And do I do that with both graphs to get two different experimental values for Mu?
  • STEM Educators and Teaching
