rkd1312
- 3
For some isotopes of some very heavy nuclei, including nuclei of thorium, uranium, and plutonium, the nucleus will fission (split apart) when it absorbs a slow-moving neutron. Plutonium-239, with 94 protons and 145 neutrons, can fission when it absorbs a neutron and becomes Plutonium-240. The two fission fragments can be almost any two nuclei whose charges Q1 and Q2 add up to 94e (where e is the charge on a proton, e = 1.6multiply10-19 coulomb), and whose nucleons add up to 240 protons and neutrons (Pu-240, formed from Pu-239 plus a neutron). One of the possible fission modes involves nearly equal fragments, silver nuclei (Ag) each with electric charge Q1 = Q2 = 47e. The rest masses of the two silver nuclei add up to less than the rest mass of the original nucleus. (In addition to the two main fission fragments there are typically one or more free neutrons in the final state; in your analysis make the simplifying assumption that there are no free neutrons, just two silver nuclei.)
The rest mass of the Pu-240 nucleus (formed from Pu-239 plus a neutron) is 240.002 u (unified atomic mass units), and the rest mass of each of the two Ag-120 nuclei is 119.893 u, where 1 u = 1.66multiply10-27 kg (approximately the mass of one nucleon). In your calculations, keep at least 6 significant figures, because the calculations involve subtracting large numbers from each other, leaving a small difference. There are three states you should consider in your analysis:
1) The initial state of the Pu-240 nucleus, before it fissions.
2) The state just after fission, when the two silver nuclei are close together, and momentarily at rest.
3) The state when the silver nuclei are very far away from each other, traveling at high speed.
(a) Calculate the final speed v, when the silver nuclei have moved very far apart due to their mutual electric repulsion. Keep at least 6 significant figures in your calculations. In your analysis it is all right to use the nonrelativistic formulas, but you then must check that the calculated v is indeed small compared to c. (The large kinetic energies of these silver nuclei are eventually dissipated into thermal energy of the surrounding material. In a nuclear reactor this hot material boils water and drives an electric generator.)
pf=pi+Fdeltat
U=q1q2/(couloumb constant)*r
K=.5*m*v^2
I tried using the the diameter of an average nucleus as the radius but it doesn't work
(47*1.6e-9)^2/(9e9)(1.6e-15)=3.9e-10
3.9e-10=.5*(119.893*1.66e-27)*(v)^2=6.28m/s
which is wrong
