Physics problem involving rotational motion.
In summary, a question from the 2011 IIT-JEE exam asked about the motion of a ring after a collision with a ball. The correct answer was deemed to be either A and C or B and D, with grace marks given to all students who attempted it. The mistake in the problem is that while the ring was rolling there was no friction force, but after the collision, there should be a friction force to the left causing the ring to first come to a stop and then rotate in the opposite direction.
shivamparke
The question is given in the following pictures.
http://imageshack.us/photo/my-images/851/iitjee2011.png/
http://imageshack.us/photo/my-images/844/iitjee20112.png/
This question had one or more than one correct answer(s).
This was asked in IIT-JEE 2011 (which is regarded by some as the toughest engineering entrance exam in the world)
The problem is that,after much debate,it was deemed as WRONG (I don't know why).Although the institute's website displayed either A or BOTH A and C as the correct answer(s),grace marks were given to all the students who attempted it.
All I want to know is the MISTAKE in this problem.
I am using - "M,r,v and ω1 and ω2" as the mass,radius,velocity and angular velocity of the ring before and after the collision respectively.
"m,Vx,Vy,x and h" as the mass of the ball,velocity of the ball before collision(x-direction),velocity of the ball after collision (y-direction),perpendicular distance between center of ring and the direction of ball's velocity after the collision and the height above the ground at which the ball hits the ring,respectively.
Given : M = 2 kg , r = 0.5 m , v = 1 m/sec ; m = 0.1 kg , Vx = 20 m/sec , Vy = 10 m/sec , h = 0.75 m , x = sq.root of (1/4 - 1/16) = 0.433 m .
Also I is the moment of inertia of the ring (Mr^2) = 0.5 kg m^2
Taking the left direction as negative,upward as positive,anticlockwise rotation as positive and applying the law of conservation of angular momentum,
→ Iω1 + m(Vx)(h-r) - Mvr = m(Vy) + Iω2
→ ω1=v/r ( pure rolling ) = 2 rad/sec
→ 0.5 = 0.433 + Iω2
→ ω2 = 0.134 rad/sec (is in the anticlockwise direction because it is positive) ...1
Applying law of conservation of linear momentum,
→ mV - Mv = 2-2 = 0
So linear velocity of ring after collision will be zero ... 2
From results ...1 and ...2 we can say that the ring will not move but will only rotate about it center of mass.So option A is correct(according to me)
I think option C is also correct becasue friction will be towards left as it has the ring will have a tendency to slip towards right.
What is confusing me is that during pure rolling(as mentioned in option A) friction does not act so after the collision it shall first slip and then purely rotate about its com .
I want to if I am wrong anywhere and also what is WRONG with this problem ?
Thanks.
→ 0.5 = 0.433 + Iω2
→ mV - Mv = 2-2 = 0
Thanks.
If the ring is in pure rotation (no translation) then the bottom of the ring must be slipping on the surface. While it was rolling, it was not slipping, so had no friction force, but while it is rotating there should be a friction fore to the Left.
Clearly the answer will be A & C or B & D.
I see the problem as one of establishing that translational momentum is reduced to zero, but rotational momentum is not - as you did.
Due to friction (towards left) there will be a clockwise torque and since the ring is rotating initially in the anticlockwise direction it will first come to a stop and then rotate (without slipping) in the clockwise direction.Am I right ?
I don't think so.
The friction force to the Left will gradually accelerate the hoop to the left, so that it eventually resumes rolling to the Left. Not enough information to determine whether it will regain its original speed - it might even end up traveling faster.
I would expect the hoop to behave in a similar way to a cue ball in billiards that has rapid spin before striking another ball full on.
The cue ball first stops [elastic collision with an equal mass object] then the effect of the spin takes over and the cue ball either comes back (if you used back spin) or follows through (if you used top spin)
The back spin example is easy to replicate with a hula hoop. You can toss it forward with rapid back-spin. It first stops, then runs back to you.
The hoop in this problem stops because of the collision with the other mass, not by the cumulative affect of the friction.
Thanks for your help.:approve:
Related to Physics problem involving rotational motion.
1. What is rotational motion in physics?
Rotational motion in physics is the movement of an object around a fixed axis. It involves the rotation of an object at a constant or changing speed.
2. How is rotational motion different from linear motion?
Rotational motion involves the movement of an object around a fixed axis, whereas linear motion involves the movement of an object in a straight line.
3. What are the key concepts of rotational motion?
The key concepts of rotational motion include angular displacement, angular velocity, angular acceleration, and moment of inertia. These concepts help us understand the rotational motion of objects.
4. How is rotational motion measured?
Rotational motion is measured in terms of angular displacement (in radians), angular velocity (in radians per second), and angular acceleration (in radians per second squared).
5. What are some real-life examples of rotational motion?
Some real-life examples of rotational motion include the spinning of a top, the rotation of a bicycle wheel, the swinging of a pendulum, and the spinning of a planet around its axis.
