Physics problem involving sum of torques
In summary, the problem involves finding the distance a cat weighing 80N can walk on a 5m beam with a weight of 100N placed on a fulcrum at an angle of 20 degrees before the beam tips. The solution involves calculating the torques from the weight of the beam and the cat, and taking into account the weight of the beam on the right side of the fulcrum.
hholzer
37
Given a beam of 5 meters and uniform weight 100N position on a fulcrum
such that it subtends an angle of 20 degrees and the length of the beam
to the left of the fulcrum is 3.3m, how far could an 80N cat walk before
the beam tips?
Here is an image that I drew up in mspaint:
http://i52.tinypic.com/2ntbqqb.png
Clearly, we want the sum of the torques.
T_1 + T_2 + T_3 = 0
where T_i = r*F
where r is the perpendicular distance from the axis of rotation
to the force F.
My thoughts were as follows:
we have three torques(from left to right):
T_1(keeping the beam down),
T_2(from the fulcrum),
T_3(from the cat)
T_2 can be ignored as it is in line
with the axis of rotation, i.e.,
it contributes nothing.
T_1(from the weight of the beam,
keeping it down) would be
the center of gravity of the beam of
3.3m, which for a uniform beam that
is 100N over 5m, would be 66N.
This center of gravity would intersect
with the perpendicular distance from the
axis of rotation, which would be (3.3/2)*cos(20).
Hence, T_1 = 66N*(3.3/2)*cos(20)
and it is positive as it works in the CCW direction.
T_3 would operate in the CW direction and
hence be negative; also, the distance from the
point to where the beam tips from the cat walking
on to it would be x*cos(20) and given that
the cat is 80N, we end up with:
- T_3 = - x*cos(20)*80N
Thus,
T_1 - T_3 = 0
T_1 = T_3
and we solve for x.
But, this is not right. I am missing
something conceptually. However,
I'm not seeing what that is.
Maybe I need to account for the weight
of the fulcrum?
something Maybe I need to account for the weight
of the fulcrum?
That's correct. Or you could consider the weight of the entire beam located at its cg half way (2.5 m) up the beam.
That is much easier, actually. Thanks for the reply.
FAQ: Physics problem involving sum of torques
1) What is the definition of torque?
Torque is a physical quantity that measures the tendency of a force to rotate an object about an axis or pivot point. It is calculated by multiplying the force applied by the distance from the axis of rotation.
2) How is torque related to angular acceleration?
Torque and angular acceleration are directly proportional to each other. This means that a larger torque will result in a larger angular acceleration, and vice versa.
3) How do you calculate the sum of torques in a physics problem?
To calculate the sum of torques, you must first determine the individual torques acting on an object. Then, add up all of the torques, taking into account their direction (clockwise or counterclockwise). The sum of torques will be the net torque acting on the object.
4) What is the significance of the direction of torque?
The direction of torque is important because it determines whether the object is rotating clockwise or counterclockwise. This can affect the object's motion and stability.
5) How can you determine the equilibrium point in a physics problem involving sum of torques?
The equilibrium point is where the sum of torques acting on an object is equal to zero. This means that the object is not rotating and is in a state of balance. To determine the equilibrium point, set the sum of torques equal to zero and solve for the unknown variable.
