Physics projectile motion question
In summary, a gold ball is thrown with an initial velocity of 52 m/s at an angle of 50 degrees and it will hit the ground in 8 minutes.
Krookwood
a gold ball is hit with an initial velocity of 52m/s at an angle of 50 degrees
How long is it in the air
Sin=opp/hyp
Cos=adj/hyp
D=vt+1/2at^2
First I split the vector into its vertical and horizontal components
sin50=x/52
52sin50=x
x=39.83m/s (up)
cos50=x/52
52cos50=x
x=33.4m/s (Horizontal)
Then I use the kinematic equation to find the amount of time it is in the air considering its total vertical displacement will be 0
dv=v1*t+1/2a*t2
0=(39.83m/s)(t) + 1/2 (-9.8m/s2)t2
i then factor out "t" and this is where I'm having an issue. I get my equation to look like this
0=t(39.83m/s - 4.9m/s2 t)
and the supposed answer is "0 or 8.1" however I'm unable to get this same result, I may be forgetting something so if anyone could explain how I get this number I'd greatly appreciate it.
You need to take care to express both the vertical and the horizontal equations of motion and to distinguish them from each other. Your symbols are also confusing position and velocity.
Krookwood said:
how far will a football travel when it is thrown at 62km/h at an angle of 35 degrees to the ground.
Sin=opp/hyp
Cos=adj/hyp
D=vt+1/2at^2
sin50=x/52
52sin50=x
x=39.83m/s (up)
cos50=x/52
52cos50=x
If your ##V_0 = 62\frac{km}{h}## and your angle is 35°, why are you using ##V_0 = 52\frac{km}{h}## and an angle of 50°
sorry i wrote the wrong question I've corrected it
I also think that the question isn't about how far the ball will travel, but after how much time it will hit the ground
yeah sorry, I have a lot of work to do and I'm making mistakes. sorry.
It's okay, just look at your result
Krookwood said:
dv=v1*t+1/2a*t2
and think of what the problem is asking you
I'm having severe math block and honestly, can't figure it out. This is a support question for an online class so after you give them the answer they give you the answer and the correct steps to follow, it takes about 3 days for a teacher to reply so essentially I have no one to ask. everything is right for me until this point, and I'm unsure what jump they made to get "0 or 8.1"What steps do you use to add 39.83m/s with -4.9m/s2
You want to find the time the ball will take to hit the ground during its motion. The equation for displacement along the y-axis is ##y(t) = v_yt-\frac{g}{2}t^2##. By setting ##y(t) = 0##, like you did, you will find the time the ball takes to hit the ground. ##0 = t(v_y - \frac{g}{2}t)##. Both sides of the equation should be zero, so you have to find the values of t(it's a quadratic equation, so you expect two solutions) for which the right side is zero.
Likes Krookwood
Thanks so much for the help, i don't know how i didn't realize that i needed the quadratic equation especially considering i had two possible results given.
Its easy. Just do 52mph * 50/ph (angle), and you get 50*52 seconds which is 8 minutes
source: pHd in kemistry at harverd
FAQ: Physics projectile motion question
1. What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity. It follows a curved path known as a parabola.
2. What are the factors that affect projectile motion?
The factors that affect projectile motion are the initial velocity, angle of launch, air resistance, and gravity. These factors determine the shape and distance of the projectile's path.
3. How is the velocity of a projectile calculated?
The velocity of a projectile can be calculated using the formula v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration due to gravity, and t is the time elapsed.
4. What is the relationship between the angle of launch and the range of a projectile?
The range of a projectile is directly proportional to the sine of twice the angle of launch. This means that as the angle of launch increases, the range also increases, but it reaches a maximum value at 45 degrees.
5. How does air resistance affect projectile motion?
Air resistance, also known as drag, can slow down a projectile and change its trajectory. It is influenced by factors such as the shape and size of the projectile, as well as the air density and speed. In some cases, air resistance can also cause the projectile to deviate from its intended path.
