Physics question about half life / radioactive decay
In summary, the problem involves calculating the number of half-lives an unstable element has undergone based on the amount of stable daughter product present. The equation used is N=No (1/2)^(t/(t1/2)), where N represents the final activity, No is the original activity, t is the time, and t1/2 is the half-life. The key concept to understand is that as the unstable element decays, its mass decreases while the mass of the stable daughter product increases. Therefore, the mass of the daughter product can be used to determine the original mass of the unstable element.
RRmy0440
You have 0.0625 grams of an unstable element and 0.9375 grams of the stable daughter product. How many half-lives has it undergone?
In which
N represents the final activity for a period of time
t represents the time
t1/2 represents the half life
(One could also be written as
(log N/No)÷(log1/2)=t/(t1/2)
I was rather confused about this question from the very beginning, I was wondering why is there more mass of the stable daughter product than the mass of this unstable element. Shouldn 't it always be that the daughter product have lesser mass than the element originally have, since it was undergoing a radioactive decay?
The correct answer for this question is 4 half lives.
One of my friend told me that if he add this two variables together, and states the result as real original mass of this unstable element,which turns into:
No=0.9375+0.0625=1g
Then applied the equation on the above, he then got the answer. But it does not make sense to me.
Can anyone help me with this question and explain the principle behind that please?I would be super grateful if you do that.
The mass is not the mass of one nucleus of the element, it is the total mass in the sample of the element.
If all of the unstable element had decayed, then there would only be the daughter element left and it would have all the mass.
No. Suppose you had 5 radioactive atoms. Now 3 of them decay, so you have 2 radioactive and 3 daughters.
Are you saying for some reason that you expect even after 3 of them decay, there are still more original than daughters? Why?
Now suppose all 5 of the original atoms decay. 0 original atoms left. 5 daughters. Are you saying that you STILL think you have more original than daughters? Why?
As the radioactive atom decays, their mass decreases. The mass of daughters increases. Sooner or later the second one is bigger than the first one.
So it appears the assumption is that the 0.9375 g of daughter came from 0.9375 g of unstable atom. The mass lost was negligible.
If you saw 2 unstable atoms and 3 of the stable decay product and wanted to know how many unstable atoms you started with, you would say "these 3 daughter atoms came from 3 unstable atoms. So I started with 3 more than I have now. There were 5."
You see 0.9375 g of daughter. You assume that came from 0.9375 g of unstable atom that decayed. So there was originally 0.9375 g more than there is now.
Thank you very much, I got it now.
Your reply is pretty helpful to me, thank you so much.
FAQ: Physics question about half life / radioactive decay
What is half life in physics?
Half life in physics refers to the amount of time it takes for half of a radioactive substance to decay into a more stable form. This is a constant rate of decay and is unique to each radioactive element.
How is half life calculated?
The calculation for half life involves using the decay constant, which is the probability that a radioactive atom will decay in a given time period. The formula for half life is: t1/2 = ln(2)/λ, where t1/2 is the half life, ln(2) is the natural logarithm of 2, and λ is the decay constant.
What factors can affect the half life of a substance?
The half life of a substance can be affected by several factors, including temperature, pressure, and the chemical environment. These factors can alter the decay constant and therefore change the rate of decay.
What is the difference between half life and mean life?
Half life and mean life are both measures of the decay rate of a substance, but they differ in their calculations. Half life is the time it takes for half of a substance to decay, while mean life is the average time it takes for all of the substance to decay.
How is the concept of half life used in real life?
The concept of half life is used in various fields, including medicine, archeology, and environmental science. In medicine, it is used to determine the dosage and frequency of radioactive treatments. In archeology, it is used to date artifacts by measuring the amount of decay in certain elements. In environmental science, it is used to track the movement and decay of pollutants in the environment.
