Physics question momentum, energy, strength of steel, PSI etc
In summary: So the front of the car has to be very strong, and the rest of the car is designed to distribute the energy so it doesn't damage the passengers.
trampoline
1.) If a car is in a frontal crash test, and goes hurling into a steel wall for instance, what unit of measure is used to define the strength of the steel wall? For instance, is the resistance strength of the steel measured in tensile strength, yield strength or something else?
2.) Another example... if the car is traveling and its energy is measured in foot pounds [lbf / ft^2] or even in joules...and it smashes into the steel wall...how would the walls resistance to the cars impact be measured?
3.) Let's say, this steel is measured perhaps in yield strength (ksi or thousands of pounds per square inch) is the force per square inch where deformation exists in the steel.
How it this to be understood? Let's assume that an imaginary vehicle is so heavy/dense that it is capable of smashing through the steel impact wall. The vehicle is 10 feet wide and 5 feet high. How is the size and weight of the vehicle divided up against all those square inches of steel to allow a hole to form?
I guess what I'm trying to understand is if the strength of the steel is measured according to thousands of pounds per square inch, is that "single unit's" strength multiplied by the total area that the imaginary vehicle impacts it and smashes a hole in the steel?
What formula would be used to compute this?
This sprung from my kids homework (not a homework question in and of itself) and we're just trying to understand how this works in theory.
Hope this makes sense. Thanks.
With metals its not about resistance its about ductility. The ductility of a metal is how easy it is for the atoms to move, metals are ductile because they have delocalised electrons.
If the objective is to stop the vehicle, then you have to make all of its kinetic energy do some work, that is not reversible. (As an example of a reversible device, suppose the "wall" was actually a thick steel plate mounted on a huge spring. The kinetic energy of the car would compress the spring and the car would stop, but the spring would then extend again and throw the car off in the opposite direction)
The easiest way to do this is to deform the wall and the car plastically (just like bending a metal paperclip so it doesn't spring back to its original shape). To get plastic deformation, you have to exceed the yield stress of the material. But if you exceed it by too much, you will break the material, or punch a hole through it. So the questions you have to answer to design the wall are first how much volume of material you need to deform plastically to take up all the energy, and then where to put that material so it actually does absorb the energy without breaking.
A lot of the energy will be is absorbed in plastic deformation of the car, as well as the wall. The front of a car is designed to "crush" and absorb energy, but without transmitting enough force to crush the passenger cabin (and the passengers.)
FAQ: Physics question momentum, energy, strength of steel, PSI etc
1. What is momentum in physics?
In physics, momentum is a measure of an object's motion, calculated by multiplying its mass and velocity. It is a vector quantity, meaning it has both magnitude and direction. The greater an object's momentum, the more difficult it is to change its state of motion.
2. How is energy related to momentum?
Energy and momentum are related through the principle of conservation of energy. In a closed system, the total energy and momentum remain constant. This means that if one changes, the other must also change to maintain the balance. For example, when a car crashes into a wall, its momentum decreases, but the energy is transferred to the wall in the form of sound, heat, and deformation.
3. What is the strength of steel?
The strength of steel refers to its ability to withstand stress without breaking or deforming. It is measured in units of force per unit area, typically in megapascals (MPa) or pounds per square inch (PSI). The strength of steel can vary depending on its composition, treatment, and temperature, but on average, it has a tensile strength of about 400 MPa or 58,000 PSI.
4. How is the strength of steel determined?
The strength of steel is determined through various tests, such as tensile strength, yield strength, and hardness. Tensile strength measures the maximum stress a material can withstand before breaking, while yield strength measures the stress at which the material begins to deform permanently. Hardness, on the other hand, measures the material's resistance to indentation or scratching.
5. What is PSI and how is it used in physics?
PSI stands for pounds per square inch and is a unit of pressure commonly used in physics. It measures the amount of force applied over a given area, and it is often used to measure the pressure of gases and liquids. In physics, PSI is used to calculate the force exerted by an object, such as air pressure, water pressure, or tire pressure.
