Physics Spring Compression Equation
In summary, the appropriate equation to solve this problem is $mgL = \frac{1}{2}k(\Delta x)^2 - mg\Delta x$. This equation takes into account the initial gravitational potential energy and the potential energy of the spring. It is important to set an origin for the spring potential energy at the top of the uncompressed spring and choose a positive direction in the direction of the spring compression.
Dethrone
717
Suppose a mass, $m$, is dropped from a height $L$ relative to the top of a uncompressed spring, which is on the surface of the floor. Calculate the compression, $\Delta x$ of the spring, given the mass.
Okay, so I completely made up this question, but here is my confusion:
Which equation is appropriate to solve this?
$$mgL=\frac{1}{2}k(\Delta x)^2-mg \Delta x$$
OR
$$mgL=\frac{1}{2}k\Delta x^2$$
Mathematics news on Phys.org
Do you have any information regarding the stiffness of the spring? Are you considering that the weight of the mass is still working on the spring as it's being compressed?
All needed values are given, including $k$. I'm not sure whether or not the mass is still working on it...the question (from my test) was simply the effect of the mass dropping on an uncompressed spring, and finding its compression/deflection, or whatever you want to call it :D
Well, obviously energy considerations are the way to go here, as you are doing. The initial gravitational potential energy, will be converted into the potential energy of the spring.
I would say your first equation is correct, since it accounts for the additional gravitational energy lost during compression.
Looks good to me. Typically we set an origin for the spring potential energy to be at the top of the uncompressed spring as the spring has no PE there and choose a positive direction in the direction of the spring compression. So you can actually get rid of the deltas there.
-Dan
FAQ: Physics Spring Compression Equation
What is a Physics Spring Problem?
A Physics Spring Problem involves the study of the behavior and characteristics of a spring when a force is applied to it. This is often used to model real-world systems and analyze their motion and energy.
How do you calculate the force exerted by a spring?
The force exerted by a spring can be calculated using Hooke's Law, which states that the force is directly proportional to the displacement of the spring from its equilibrium position. The formula for this is F = -kx, where F is the force, k is the spring constant, and x is the displacement.
What is a spring constant?
A spring constant is a measure of the stiffness of a spring. It represents the amount of force required to stretch or compress a spring by a certain amount. It is often denoted by the letter k and has units of N/m.
What is the period of a spring?
The period of a spring is the time it takes for the spring to complete one full oscillation, or back-and-forth motion. It is affected by the mass of the object attached to the spring, the spring constant, and the amplitude of the motion.
How does the mass of an object affect a spring's behavior?
The mass of an object attached to a spring affects its behavior by changing the system's frequency and period. A higher mass will result in a lower frequency and longer period, while a lower mass will result in a higher frequency and shorter period. This is because the mass affects the amount of force required to stretch or compress the spring.
