Physics Summer Assignment Question
The discussion revolves around a physics homework problem involving the calculation of force using Coulomb's law. The user clarifies that the "x" in the formula represents multiplication, not a variable. They seek guidance on how to approach the problem rather than a complete solution. The formula provided includes constants for electrostatic force and charges, along with the distance squared. The user is looking for direction to help them understand the problem better.
jbmiller
121
F=(9.0x10^9Nxm2/C2)(3.2x10^-9C)(9.6x10^-9C)/(0.32m)^2
The x in between the N and m is a multiplication symbol, not a variable.
I'm not asking anyone to solve this for me, I just need a little direction. Thanks in advance.
What is the question?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
