Zeus5966
- 10
A uniform disk with mass m = 9.27 kg and radius R = 1.42 m lies in the x-y plane and centered at the origin. Three forces act in the +y-direction on the disk: 1) a force 344 N at the edge of the disk on the +x-axis, 2) a force 344 N at the edge of the disk on the –y-axis, and 3) a force 344 N acts at the edge of the disk at an angle θ = 39° above the –x-axis.
Diagram: https://www.smartphysics.com/Content/smartPhysics/Media/Images/Mechanics/15/torqueondisk.png
1) What is the magnitude of the torque on the disk about the z axis due to F1?
2) What is the magnitude of the torque on the disk about the z axis due to F2? = 0, this was correct
3) What is the magnitude of the torque on the disk about the z axis due to F3? = 379.6, this was correct
4) What is the x-component of the net torque about the z axis on the disk?
5) What is the y-component of the net torque about the z axis on the disk?
6) What is the z-component of the net torque about the z axis on the disk?
7) What is the magnitude of the angular acceleration about the z axis of the disk?
8) If the disk starts from rest, what is the rotational energy of the disk after the forces have been applied for t = 1.8 s?
torque = F * r * sin(theta)
torque = I * alpha
1) torque = F * r * sin(theta)
so torque = (344N) * (1.42) * sin(90)
the answer I get is 488N*m but it says it's incorrect. I'm also not sure how to convert the sin(90) to the z axis instead of the x-y axis.
4) I can't actually find this until I get 1 correct, however, it would be the sum of all torque, so
Ʃtorque = torquey + torquex + torquez where torquez and torquey are to be transferred into the y direction, but multiplying by sin(90)?
5/6, same method as above
7) The equations I used are torque = I * alpha, torque = F * r, I = 1/2 * mdisk * radius2
rearranging, I * alpha = F * r so
alpha = F * r / I where
to end up with
alpha = F*R/(1/2 * mdisk * radius2)
alpha = 344 * 1.42 / (1/2 * 9.27 * 1.422)
alpha = 52.267 rad/s2 <- seems too high
8) Krotational = (1/2) * I * ω2 where ω = alpha * t and I = 1/2 * mdisk * radius2
so K = (1/2) * (1/2 * mdisk * radius2) * (alpha * t)2
K = 551.278J
Thanks for the help
