MHB Physics-Using vectors to find the components
The trapper walks a straight-line distance of 6.2 km at an angle of +45 degrees, resulting in east and north components of 4.38 km each. To find the total distance if walking along the component displacements, one must sum the two components, yielding 8.76 km. The additional distance the trapper would need to walk is calculated by subtracting the actual distance (6.2 km) from this sum. This results in a need for an extra 2.56 km of walking. The discussion emphasizes the importance of vector components in calculating displacement and additional distance required.
cbarker1
MHB
Hello Everybody,
A trapper walks a 6.2 km straight-line distance from the cabin to the lake, beginning to the lake has an angle of +45 degrees. Determine the east and north components of her dispacement vector.
Work:
E component: $6.2\times\cos\left({45^{\circ}}\right)$ = 4.38
N Component:$6.2\times\sin\left({45^{\circ}}\right)$=4.38
I have troubles to next question:
How many more kilometers would the trapper have to walk if she walked along the component displacements?
Mathematics news on Phys.org
You've found the length of the components, so if the trapper walks along the components, that distance would be the sum of the two components. To answer the question you would then need to subtract the actual distance walked from this sum. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
