Noles1
- 18
A string is tied on both ends and under a tension FT. A standing wave is formed on the string. For each of the following statements select the correct option.
1.)If the distance between the two fixed ends of the string is increased, the wavelength that corresponds to the fundamental frequency ...
2.) When the amplitude of the wave is decreased, the fundamental frequency ...
3.) If the distance between the two fixed ends of the string is decreased, the fundamental frequency...
4.) If the distance between the two fixed ends of the string is increased, the wave speed ...
5.) When the tension of the string is increased, the fundamental frequency...
**for each number, the answer (which is the end to the sentence) is either increases, decreases, or stays the same.**
I'm not really sure what relevant equations would be. I know f=v/wavelength...
I've tried a solution with many different combinations of the answer, but I am still unable to figure it out...even after thoroughly reviewing the material in the book/notes.
