Picking an element type for FEA
In summary, the conversation discusses the advantages of using 8-node elements with mid-side nodes for FEA stress analysis. These elements offer more flexibility in dealing with curved or non-uniform surface geometries and allow for higher order interpolation between nodes, resulting in smoother stress calculations. The use of mid-side nodes is especially beneficial when mesh density is limited.
mattyboson12
41
When choosing between a 2D 4-node quadrilateral element and 8-node for FEA stress analysis, why is the 8 node option preferred? I understand it has much more flexibility with different shapes due to the central mid node but are there any other reasons?
This article gives a useful practical overview of mid-side node elements for stress calculation in ANSYS: http://www.padtinc.com/blog/the-focus/mid-side-nodes-do-they-really-help
The advantages of elements with mid-side nodes are two fold:
  1. The sides of the element can better follow curved or non-uniform surface geometries
  2. Straight-sided (a.k.a. linear) elements only have two elements along any edge, so only linear interpolation is available between the nodes; if mesh density is limited, this can become a problem. FEA elements with mid-side nodes along each side allow for order (n-1) interpolation, so in the case of an element with single mid-side nodes (3 nodes per edge), 2nd-order quadratic interpolation is possible between nodes which in some cases results in smoother stress calculations.
Thank you
Related to Picking an element type for FEA
1. What is an element type in FEA?
An element type in FEA (Finite Element Analysis) refers to the specific shape and mathematical representation used to model a physical object in the analysis. Each element type has its own unique set of characteristics and equations that are used to calculate the behavior and response of the object under different loading conditions.
2. How do I choose the right element type for my FEA analysis?
Choosing the right element type for FEA depends on various factors such as the geometry of the object, the type of analysis being performed, the material properties, and the desired level of accuracy. It is important to consult with experienced engineers and conduct thorough research to determine the most suitable element type for your specific analysis.
3. What are the most common element types used in FEA?
The most common element types used in FEA include linear and quadratic elements, such as 1D beam elements, 2D plane stress/strain elements, and 3D solid elements. There are also specialized element types for specific applications, such as shell elements for thin structures, and axisymmetric elements for cylindrical objects.
4. Are there any limitations to using a certain element type in FEA?
Yes, there are limitations to using certain element types in FEA. For example, linear elements may not accurately capture nonlinear behavior, and 2D elements may not accurately represent complex 3D geometries. It is important to understand the limitations of each element type and choose the appropriate one for your analysis.
5. Can I use a combination of element types in my FEA analysis?
Yes, it is possible to use a combination of element types in FEA. This is often done to accurately model complex geometries or to capture both linear and nonlinear behavior. However, it is important to ensure compatibility between the different element types and to carefully interpret the results to avoid errors.
  • Mechanical Engineering
13K
  • General Engineering
