Picky about initial velocity condition
In summary, in simple kinematic problems, the initial velocity can be either zero or some nonzero value. The reason for this is that it depends on the specific situation and what part of the motion is important. For example, in the case of a rocket taking off, the initial velocity may be zero if we are only looking at the motion after the first stage boosters have been exhausted. However, in the case of a block being pushed with an impulsive force, the initial velocity may not be zero because the velocity change in a short amount of time is significant. This explanation may vary depending on the specific situation and what is being focused on.
fisico30
374
In simple kinematic problems,
the initial velocity can be zero or some nonzero value.
A friend asked me: what makes it zero in some cases and nonzero in some others.
Take a rocket in take off. It has acceleration moving upward, from the beginning, but its v_0=0.
Instead, if I apply an impulsive force on a tiny block on a table and then let it go, we say that there is a certain v_0...
Do we have to assume that they both are actually starting from zero speed, but over a very small delta_t, the average velocity of the rocket is still very very small (amost zero), and that average velocity corresponds to the instantaneous velocity at that point.
In the case of the small block being pushed with an impulsing force, the instantaneous velocity is not taken as zero, because the velocity change in that short delta_t is not negligible...
IS this a correct explanation?
thanks
It depends which part of the motion is important for you. I mean depends on the situation. For your rocket example, if I am interested in the motion after the first stage boosters have been exhausted, my initial velocity will not be zero.
Yes, your explanation is correct. In simple kinematic problems, the initial velocity can be either zero or some nonzero value. This is because the initial velocity is dependent on the specific situation and the forces acting on the object. In the case of the rocket, the initial velocity is zero because it is initially at rest and must accelerate upwards to take off. However, in the case of the small block being pushed with an impulsive force, the initial velocity is not zero because the force applied on the block causes a change in its velocity over a short period of time. This is why the instantaneous velocity is not taken as zero. It is important to consider the specific conditions and forces at play in order to determine the correct initial velocity in kinematic problems.
FAQ: Picky about initial velocity condition
What is the initial velocity condition?
The initial velocity condition refers to the starting velocity of an object in motion. It is the speed and direction at which an object is moving at the beginning of its motion.
What factors affect the initial velocity condition?
The initial velocity condition can be affected by various factors such as the force applied, the angle of launch, and the mass of the object. Other factors may include air resistance, friction, and gravity.
Why is the initial velocity condition important in scientific experiments?
The initial velocity condition is crucial in scientific experiments as it helps determine the trajectory and behavior of an object in motion. It also allows for accurate predictions and analysis of the experiment's results.
How can the initial velocity condition be measured or calculated?
The initial velocity condition can be measured or calculated using various methods such as video analysis, motion sensors, or simple mathematical equations. The method chosen will depend on the experiment and the available resources.
Can the initial velocity condition be changed during an experiment?
Yes, the initial velocity condition can be changed during an experiment by altering the variables that affect it. However, it is essential to maintain a controlled experiment and only change one variable at a time to accurately study the effects on the object's behavior.
