Picture of Bragg's diffraction sounds confusing
In summary, the conversation was about Bragg's Law of Diffraction and the confusion surrounding interference between two wave beams hitting different points on a detector screen. The explanation provided by Wikipedia states that the waves can undergo constructive interference if the path difference is equal to an integer value of the wavelength, but this may be difficult to visualize. However, it was clarified that the beams are not perfectly parallel, but they are almost parallel and intersect at some point on the screen. This understanding can help in deriving the path difference of 2d sin θ.
kasha
This may be a little of a stupid question.
But I was looking at a diagram describing Bragg's Law of Diffraction.
and I was like...how can an interference happen if wave beam C and wave beam C' are hitting different points on the detector screen?! they are not hitting the same point on the detector.
Per Wikipedia: The two separate waves will arrive at a point with the same phase, and hence undergo constructive interference, if and only if this path difference is equal to any integer value of the wavelength...but how would they arrive at the same point? I think the graph is very confusing.
Any help to clear things up would be very appreciated...
Science news on Phys.org
The beams are much wider than the plane spacing. You actually have many many parallel incoming rays and many many parallel outgoing rays. Try shifting one of the rays in the diagram horizontally so that the outgoing rays coincide. With this new diagram, deriving the path difference to be 2d sin θ is more complicated, but it can be done.
I actually found the answer for that...
First: the lines are not perfectly parallel, they are almost parallel. over the very short distance (d in Angstrom) the paths of the reflected x-rays C and C' are pretty much parallel, but over the distance of the screen of the detector let's say it is L...the lines are not parallel. it is safe to assume the lines are parallel in our calculations inside the Crystal Latex...but they do intersect at some point on the screen.
FAQ: Picture of Bragg's diffraction sounds confusing
What is Bragg's diffraction?
Bragg's diffraction is a phenomenon in which a beam of X-rays or neutrons is scattered by a crystal lattice, resulting in a pattern of spots on a detector. This pattern can be used to determine the structure of the crystal.
How does a picture of Bragg's diffraction look like?
A picture of Bragg's diffraction typically shows a series of spots or rings on a black background. The spacing and intensity of these spots or rings can provide information about the crystal structure and the wavelength of the incident radiation.
Why does the term "diffraction" sound confusing in relation to this phenomenon?
The term "diffraction" can be confusing because it is often associated with the bending of waves around obstacles, which is not exactly what happens in Bragg's diffraction. Instead, the scattering of the radiation by the crystal lattice causes interference patterns that result in the observed spots or rings.
How is Bragg's diffraction used in scientific research?
Bragg's diffraction is a powerful tool for studying the structure of materials. It is commonly used in X-ray crystallography to determine the atomic and molecular structures of proteins, minerals, and other materials. It is also used in neutron diffraction to study the magnetic properties of materials.
Can Bragg's diffraction be used in any other fields besides materials science?
Yes, Bragg's diffraction has applications in various fields, including biology, chemistry, and physics. It can be used to study the structure of biological molecules, such as DNA and proteins, and to analyze the composition of materials in forensic science. It is also used in the development of new materials for electronics and energy storage.
