Piezoelectric Effect and EM Radiation
In summary, deforming a piezoelectric crystal causes electric charges to build up on the outer faces of the material, but these charges do not behave like free charges in a metal. The charge is bound and cannot move, and the crystal maintains its band structure and interacts with light in a similar way as an unstressed crystal. However, the polarized crystal can affect the index of refraction through the electrooptic and stressoptic effects, making the crystal birefringent. These three effects often occur together and can influence each other, as seen in the use of Lithium Niobate as a Pockel's cell Q-switch in high power laser cavities.
Samson4
245
It's my understanding that deforming a piezoelectric crystal causes electric charges to build up on the outer faces of the material. What I would like to know is if these charges behave like the free charges in a metal. More specifically, does deforming a piezoelectric crystal effect how em radiation penetrates the surfaces that become charged? This is considering crystals with no electrodes.
The answer to this isn’t simple. Part of the reason is that the same assymetry of the crystal lattice that causes the piezo-electric effect also causes other effects that aren’t officially directly related but wind up occurring together and influencing each other.
When you squeeze a crystal (stress) the crystal lattice (atomic cores bound together by electrons which are in covalent bonds in all the piezo materials) bends just a little (strain). The lattice of a piezo electric is assymetric in a way that the negative charge in the bonds bends a little one way while the positive atom cores shift the other. Net charge only appears on the surface. To see why, picture a rectangle filled with positive charge. Superposed over it picture a rectangle filled with negative charge. Right now the rectangle is neutral. Now picture displacing the negative charge a little to the left. All the charge moved, but most of the area is still neutral. A little excess negative charge appears on the left surface and a little excess positive charge appears on the right surface. Note that these are still bound charges. It’s not like a metal. The charge can’t move, and it hasn’t become free to interact with EM waves. The distortion is only slight and the charge has pretty much the same band structure and interacts with light about the same, transparent or absorbing, as the unstressed crystal. The lattice is elastic, and the harder you squeeze the more charge you get. (or inversely the more field you apply the more the lattice bends)
The polarized crystal is now like a parallel plate capacitor. The charge creates an electric field. The dc electric field doesn’t directly effect EM radiation. However the electric field can affect the polarizability and therefore the index of refraction through the electrooptic effect. Given the assymetry, the index change is not uniform in all directions so the crystal becomes birefringent. Squeezing the crystal displaces the atoms and this also results in birefringence through the stressoptic effect. This too makes the crystal birefringent.
These three effects, piezoelectric, electrooptic, and stressoptic often occur together to differing degrees and can influence each other. For example we use Lithium Niobate as a Pockel’s cell Q-switch in high power laser cavities. We apply an electric field to create birefringence. The electro optic effect is very fast and on short time scales you get one value of birefringence. However the electric field also causes stress via the piezoelectric effect. The piezo stress causes the crystal to distort, but it takes acoustic time scales to complete the strain. As the lattice strains you get extra birefringence through the stressoptic effect. This means the required electric field to get the desired birefringence changes completely depending on the time scale because of the interaction of these three effects. Yikes!
Likes jim hardy, vanhees71, mfb and 8 others
Beautifully articulate. Thank you very much Cutter Ketch.
Likes dlgoff, berkeman and Cutter Ketch
Related to Piezoelectric Effect and EM Radiation
1. What is the piezoelectric effect?
The piezoelectric effect is a phenomenon in which certain materials, such as crystals and ceramics, generate an electric charge when they are subjected to mechanical stress, such as pressure or vibration. This effect can also work in reverse, with the application of an electric field causing the material to deform or vibrate.
2. How does the piezoelectric effect relate to EM radiation?
The piezoelectric effect is closely related to EM (electromagnetic) radiation because it involves the conversion of mechanical energy into electrical energy. EM radiation, which includes visible light, radio waves, and X-rays, is a form of energy that travels through space in the form of electromagnetic waves. The piezoelectric effect allows for the conversion of this EM radiation into electrical energy, which can then be used for various applications.
3. What applications use the piezoelectric effect?
The piezoelectric effect has a wide range of applications, including in electronic devices such as microphones, speakers, and sensors. It is also used in medical imaging equipment, such as ultrasound machines, and in energy harvesting devices that convert mechanical vibrations into electrical energy.
4. What materials exhibit the piezoelectric effect?
Crystals and ceramics are the most commonly used materials for the piezoelectric effect, with quartz, tourmaline, and barium titanate being some of the most well-known examples. However, other materials such as bone, DNA, and certain polymers have also been found to exhibit the piezoelectric effect.
5. Are there any potential drawbacks or limitations to the piezoelectric effect?
While the piezoelectric effect has many useful applications, it also has some limitations. One limitation is that the effect is relatively small, so it may not be suitable for applications that require a large amount of energy. Additionally, the materials used for the piezoelectric effect can be expensive and may not be readily available in certain areas. However, ongoing research is focused on finding new materials and improving the efficiency of the piezoelectric effect for a wider range of applications.
  • Electromagnetism
  • Electromagnetism
  • Atomic and Condensed Matter
  • Electromagnetism
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
