MHB Pinwheel Symmetry Formulas Exposed
  • Thread starter Thread starter mathjam0990
    Color
mathjam0990
Question:
How many different pinwheels with 8 identically shaped pins are there if each pin can be colored one of 4 different colors?
My answer:
4^8 because each pin has 4 choices Is this correct? I think this only includes rotational symmetries. Do I need to consider reflectional symmetries? If so, would reflectional symmetries = 4^5?
Thank you for your help!
I'm not a specialist in combinatorics, but Wikipedia says the number is ${1\over 8}\sum_{d\mid 8}\varphi(d)4^{8/d}$.
By the way, how can a pinwheels spin if it has several pins? Do you mean 8 curls?
This is actually for an abstract algebra class. Not sure why they are teaching us combinatorics :( Also, I stated the question quote from our textbook so I am not sure. Thanks for the info though, I appreciate it.
Because Burnside's lemma involves the use of group (action) theory.
Usually, we talk about "distinct colorings"; for example, if we have for the "pins":
1 = red
2 = yellow
3 = green
4 = blue
5 = red
6 = yellow
7 = green
8 = blue
this is regarded as the same coloring as:
1 = yellow
2 = green
3 = blue
4 = red
5 = yellow
6 = green
7 = blue
8 = red
since the $8$-cycle $(1\ 2\ 3\ 4\ 5\ 6\ 7\ 8)$ takes the first to the second (that particular $8$-cycle generates the rotation group).
$4^8$ is the size of the total "configuration space" $X$ of all possible colorings where we keep track of which "pin" got painted what color. The number of "distinct colorings" is much smaller, since we might rotate one configuration into another, with no way to tell them apart (this assumes all eight "pins" are identical).
I daresay a pinwheel is being used here to avoid the harder question of including reflection symmetries (like you would have using a necklace, with beads).
Thank you Deveno for your help. The question in the book definitely stated quote pinwheel. I think it's a poorly written book and a bit ambiguous at times which doesn't help someone like me who is already not too great at this stuff. Anyway, thanks for the info!
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
