Pipe Design - One Inlet, 3 Outlets
In summary, the schematic of the problem is in the attached PDF, and the equations to solve for the conditions at 1, 2, and 3 when they are at a given length in their respective pipe are Q0=V0*A0, Q1=V1*A1, Q2=V2*A2, Q3=V3*A3. Friction factors Re0, Re1, Re2, Re3 are 1/sqrt(f0), 1/sqrt(f1), 1/sqrt(f2), 1/sqrt(f3). Head Losses HL1, HL2, HL3 are f0*(L01/D0)*(V0
TBen24
Any tips for solving this would be greatly appreciated. Thank you all for your time and help
The schematic of the problem is in the attached PDF
PROBLEM INFORMATION
I’m trying to determine the equations to solve for the conditions at 1, 2, and 3 when they are at a given length in their respective pipe. I need to solve for the pressures and velocities at states 0 – 3. Also, the gaps between the pipe branches are considerably larger than the drawing shows. In other words, the drawing is not to scale. I don’t need numbers specifically, just help on setting up the system of equations.
KNOWN
Gravity, density, roughness, kinetic energy correction factor, size of duct (all areas, lengths, and diameters)
SOLUTION ATTEMPT
Notes: Q is volumetric flow rate, epsilon is roughness, mu is viscosity, alpha is kinetic energy correction factor
Assumptions: Steady flow, inviscid flow, incompressible flow, and irrotational flow.
Converse mass
Q0 = V0*A0, Q1 = V1*A1, Q2 = V2*A2, Q3 = V3*A3
Q0 = Q1+Q2+Q3
Friction Factors
Re0 = (rho*V0*D0)/mu, Re1 = (rho*V1*D1)/mu, Re2 = (rho*V2*D2)/mu, Re3 = (rho*V3*D3)/mu
1/sqrt(f0) = -2.0*log((epsilon/D0)/3.7+2.51/(Re0*sqrt(f0)))
1/sqrt(f1) = -2.0*log((epsilon/D1)/3.7+2.51/(Re1*sqrt(f1)))
1/sqrt(f2) = -2.0*log((epsilon/D2)/3.7+2.51/(Re2*sqrt(f2)))
1/sqrt(f3) = -2.0*log((epsilon/D3)/3.7+2.51/(Re3*sqrt(f3)))
Head Losses
HL1 = f0*(L01/D0)*(V0^2/(2*g))+(f1*(L1/D1)+K1)*(V1^2/(2*g))
HL2 = f0*(L02/D0)*(V0^2/(2*g))+(f2*(L2/D2)+K2)*(V2^2/(2*g))
HL3 = f0*(L03/D0)*(V0^2/(2*g))+(f3*(L3/D3)+K3)*(V3^2/(2*g))
K1 is caused by branched tee flow in tee 1
K2 is caused by straight flow through tee 1 and branched flow through tee 2
K3 is caused by straight flow through tees 1 and 2 and branched flow in tee 3
Analysis
Based on the current setup, there will most likely be more unknowns than equations. In addition, pressure is not solved for at any of the states. I still need to relate the states.
Concerns and Questions
1) Is the head loss done correctly?
2) Can Bernoulli be applied between the various states to conserve energy? Specifically can it be applied between states 0 --> 1, 0 --> 2, and 0 --> 3 using the balances shown below despite the flow branching in several pipes?
P0/(rho*g)+alpha*(V0^2/(2*g))+L1 = P1/(rho*g)+alpha*(V1^2/(2*g))+HL1
P0/(rho*g)+alpha*(V0^2/(2*g))+L2 = P2/(rho*g)+alpha*(V2^2/(2*g))+HL2
P0/(rho*g)+alpha*(V0^2/(2*g))+L3 = P3/(rho*g)+alpha*(V3^2/(2*g))+HL3
3) Are the head losses equal because they are parallel? I personally do not think that they are because there are large gaps separating the branches?
4) Should I solve for pressure loss using head loss if the energy balance is not valid?
Thank you all again
  • Schematic Bare.pdf
As far as I can tell everything you have there is fine. The one thing you are missing are the boundary conditions. As you have 4 boundaries (ends of pipes) to calculate a unique solution to your problem you will need 4 boundary conditions (flows or heads).
Rich
One of the best ways to calculate complicated pipe networks is to use Newton-Raphson method >> http://www.firavia.com/Newton.html
this will help you hopefully .
FAQ: Pipe Design - One Inlet, 3 Outlets
What is the purpose of "Pipe Design - One Inlet, 3 Outlets"?
The purpose of this pipe design is to efficiently distribute a single source of fluid or gas to three different locations.
How does "Pipe Design - One Inlet, 3 Outlets" differ from other pipe designs?
This particular design differs from other pipe designs in that it has one inlet and three outlets, allowing for the distribution of fluid or gas to multiple locations instead of just one.
What factors are considered when designing a "Pipe Design - One Inlet, 3 Outlets" system?
The design of this system takes into account factors such as fluid flow rate, pressure requirements, pipe material and diameter, and the distance between the inlet and outlets.
What are the benefits of using a "Pipe Design - One Inlet, 3 Outlets" system?
The main benefit of this type of pipe design is its efficiency in distributing fluid or gas to multiple locations, reducing the need for separate piping systems. It also allows for easier maintenance and potential cost savings in installation and operation.
How is the flow of fluid or gas controlled in a "Pipe Design - One Inlet, 3 Outlets" system?
The flow of fluid or gas is controlled by valves placed at each outlet, which can be opened or closed to adjust the flow rate to each location. The inlet may also have a control valve to regulate the overall flow into the system.
