Pirani Gauge-Saturation Levels
  • I
  • Thread starter George444fg
  • Tags
    Levels
In summary, the experiment using Pirani gauges and different gasses showed that when using helium for pressures greater than 10 Pascal with a Krammerer gauge, the Pirani gauge pressure reading becomes saturated due to temperature dependence. The Krammerer gauge is a better option for measuring higher pressures as it is not affected by temperature changes.
George444fg
Dear community. Recently I performed an experiment using Pirani Gauges and different gasses. When I use helium for pressures greater than 10 Pascal (Using Krammerer Gauge) the pressure of the Pirani gauge becomes great and saturates at a certain value. Why this is the case.
Thank you in advance
for your help. The phenomenon you are observing is a result of the temperature dependence of the pressure reading on a Pirani gauge. When exposed to higher pressures, the temperature of the Pirani gauge increases and this causes the pressure reading to become saturated due to a limitation of the thermistor. The Krammerer gauge is more suitable for measuring higher pressures since it is not affected by temperature changes.
FAQ: Pirani Gauge-Saturation Levels
What is a Pirani Gauge?
A Pirani Gauge is a type of pressure sensor used to measure low pressures in vacuum systems. It operates by measuring the thermal conductivity of the gas in the system.
How does a Pirani Gauge work?
A Pirani Gauge works by heating a wire or filament inside the vacuum chamber. As the gas molecules collide with the heated wire, they transfer heat away from it. The temperature of the wire is then measured and used to calculate the pressure of the gas in the system.
What is meant by "saturation level" in a Pirani Gauge?
The saturation level in a Pirani Gauge refers to the maximum pressure that the gauge can accurately measure. Once the pressure in the system reaches this level, the gauge will no longer be able to accurately measure the pressure and will be "saturated".
How is the saturation level of a Pirani Gauge determined?
The saturation level of a Pirani Gauge is determined by the design and construction of the gauge, as well as the type of gas being measured. It is typically listed in the gauge's specifications and can range from a few millitorr to several hundred torr.
Are there any factors that can affect the saturation level of a Pirani Gauge?
Yes, the saturation level of a Pirani Gauge can be affected by factors such as the type of gas being measured, the temperature of the gauge, and the presence of any contaminants in the vacuum system. It is important to regularly calibrate and maintain the gauge to ensure accurate measurements.
