Pistons have cracked and put a hole in the block
In summary: The oil temperature sensor is not directly related to the engine failing, but it could indicate a problem.
audi q5
TL;DR Summary
Audi q5 2009 injector and Alternator and auxiliary belt work gone wrong
Hi all so I had a injector go on my audi q5 2009 and had a mechanic to put a new injector in it and a Alternator and auxiliary belt so after the work be done I take it for a drive did about 2miles than Start it to make Allowed tapping noise so get hold of mechanic and he's said get it home than he will come and have a look at it so start my journey again but before I get back home properly do 5/6 miles a Warning light saying oil too hot over turn engine off before I Even had the chance too Pullover a big bang and engine cuts out so gets out car oil everywhere he comes and has a look the pistol has cracked and put a hole in the block Either on chamber 3 or 4 now what I need to no is how dose a piston just do that and if the mechanic do something to it or is just bad luck
Welcome to PF.
But from your description of the work the mechanic did, they didn't go near the pistons. They only worked on the injector, alternator and belt, right?
I agree with what @berkeman said, that the mechanic's work didn't cause the problem with your engine. From your description, you're going to need a replacement engine if you want this car to run again.
Welcome to PF.But from your description of the work the mechanic did, they didn't go near the pistons. They only worked on the injector, alternator and belt, right?
No he did not working on the pistols but iv read online that if the injector is putting to much fuel in the chamber it could cause the pistol to get too hot there brake
  • Skeptical
Likes anorlunda
When he removed the injector, something might have fallen into the cylinder. That can be really bad if it blocked the piston motion somehow. At this point, something has to give.
audi q5 said:
TL;DR Summary: Audi q5 2009 injector and Alternator and auxiliary belt work gone wrong
In which cylinder did he replace the injector?
I thought of that too. But finding the debris of the dropped piece is unlikely, so the smoking gun proof will never appear.
Number 4
audi q5 said:
Number 4
Why are you not sure which piston failed? It it's for sure the same cylinder where the injector got replaced, that is a lot more suspicious.
What is the engine type and capacity ?
Is this a petrol or a common-rail diesel engine ?
If too much fuel was injected into one cylinder, then it would blow black smoke until the ECU cut the fuel supply to that cylinder.
I would;
Identify the engine model.
Pull the injectors and visually compare them.
Check the physical length and part number of the replacement injector.
A cracked piston can be caused by pre-ignition, often called 'pinging' under load.
Pre-ignition can be due to:
1) Ignition timing advanced too far
2) Lower grade of gasoline ( the Audi q5 requires Premium gas)
3) Air/Fuel ratio being too high (running lean, fuel starved)
The details are that the fuel in the cylinder ignites while the piston is still moving up in its compression stroke. If the cause is a lean fuel mixture, the temperature is also increased. The resulting extremely high pressure and high temperature can, as you found out, cause severe engine damage.
Tom
When the engine is pulled down, examine the big-end joints. It is possible that a lubrication failure seized the big-end of the connecting rod and broke the piston later in the process. That mode of failure, an event from below, would be unrelated to fuel injection.
If the big-end joints are good, then piston failure, caused by events above, would be part of the chain that caused the destruction.
Likes Tom.G
check the oil sump.
Likes berkeman
Could these be related.
Or just a coincidence, that the engine decided to fail after leaving the shop.
Something to consider an investigation.
For the oil temperature sensor to pick up an increase in temperature so quickly, exhaust gas could have been bypassing the piston and entering the sump.
In this scenario, either the piston rings and piston side became quite damaged, or a hole was punched into the top of the piston.
You, as the driver, would not notice any funny exhaust, like black or grey smoke, through the rear view mirror, before failure for three reasons.
1. you are not looking for it.
2. the smoke dissipates and blends in quickly with the vortex(es) of the rear of the moving car. ( check diesel exhaust upon heavy load, and how quickly it becomes not noticeable )
3. the smoke blends in with what is seen through a rear view mirror.
A person on the side of the road would notice.
Hot engine oil usually results from a seized bearing.
If the injector was replaced with the wrong part number, the injector might protrude too far into the combustion chamber and damage the piston. That error would come back onto the mechanic and business insurance.
But we don't even know the engine model, is it gasoline or diesel ?
Hi thanks for your replys the engine is a 2.0 tdi Diesel engine number caha
Welcome and sorry for that damaged engine. :oops:
What was wrong with the engine before the last repair?
Why was that injector replaced?
It seems to me like the typical failure by hydrolock.
Prior or after the injector replacement, liquid (coolant or diesel fuel) could have leaked inside the small combustion chamber #4 only, due to unknown causes.
Please, see:
https://en.m.wikipedia.org/wiki/Hydrolock
“Diesel engines are more susceptible to hydrolock than gasoline engines. Due to their higher compression ratios, diesel engines have a much smaller final combustion chamber volume, requiring much less liquid to hydrolock. Diesel engines also tend to have higher torque, rotating inertia, and stronger starter motors than gasoline engines. The result is that a diesel engine is more likely to suffer catastrophic damage.“
Look for a bent connecting rod, which is a typical damage by hydrolocking.
Likes jack action and anorlunda
Have you been able to download the event history from the car's ECU? You may want to have a different mechanic do the download, BTW.
Likes Lnewqban
Please, see:
Hi thanks for the reply and information
Iv just been out to check the injector codes and the one the mechanic has put In has a different code to the rest so I Believe hes put the wrong injector in
Likes Lnewqban
It may still be the correct injector, but from a different manufacturer or supplier.
Injectors come in different lengths. I expect the most likely bad mistake would be to fit an injector for the V6, to the I4 engine of the same year. I had trouble identifying the relevant injector codes because some references suggested your vehicle injector code changed twice in 18 months.
You will need to pull the replaced injector, along with at least one of the other injectors, then you can compare the length and other physical dimensions, and look for physical damage due to possible collision with the piston.
Likes jack action, audi q5 and Lnewqban
My guess is that the injector that was replaced was defective as a symptom. There was likely something going on with that piston or it's rings that caused the injector to become sooted up or something like this. I've seen it in a diesel where the intake was choked off and the injectors soon became sooted up and it started missing.
In the OP's case, poor compression on the cylinder in question probably caused this injector to go bad. That poor compression was likely caused by something going wrong with the piston or it's rings. I've seen in a gas engine where the top ring broke and after a few thousand miles ended up on top of the piston. It might seem that a piston coming apart is an all at once operation but it's not so.
Likes berkeman and Lnewqban
FAQ: Pistons have cracked and put a hole in the block
What causes pistons to crack and put a hole in the engine block?
Pistons can crack and create holes in the engine block due to several reasons, including detonation or pre-ignition, excessive heat, poor lubrication, manufacturing defects, or engine over-revving. These factors can cause extreme stress and pressure on the pistons, leading to catastrophic failure.
How can I tell if my engine block has been damaged by a cracked piston?
Signs of a damaged engine block due to a cracked piston include abnormal engine noises such as knocking or banging, loss of power, excessive smoke from the exhaust, oil contamination with coolant, and visible cracks or holes in the engine block. A thorough inspection by a professional mechanic can confirm the damage.
Can a cracked piston and a damaged engine block be repaired?
Repairing a cracked piston and a damaged engine block is often not feasible or cost-effective. In most cases, the engine will need to be replaced or rebuilt entirely. However, minor damage might be repairable depending on the extent and location of the damage. Consulting with an experienced mechanic is essential to determine the best course of action.
How can I prevent pistons from cracking and damaging the engine block?
Preventing piston and engine block damage involves regular maintenance, using high-quality fuel and oil, ensuring proper engine tuning, avoiding engine over-revving, and addressing any signs of engine detonation or pre-ignition immediately. Regular inspections and timely repairs can also help prevent severe damage.
Is it safe to drive with a cracked piston and a damaged engine block?
No, it is not safe to drive with a cracked piston and a damaged engine block. Doing so can lead to further engine damage, complete engine failure, and potential safety hazards. If you suspect such damage, it is crucial to stop driving the vehicle and seek professional mechanical assistance as soon as possible.
