Pivot doing work on the rotating rod
In summary: Because the hinge is exerting a force perpendicular to the rod, it would do work on the surface it's touching. Okay, so you're treating the surface as an entire entity/point, correct? Because the hinge is exerting a force perpendicular to the rod, it would do work on the surface it's touching.
LiftHeavy13
http://dev.physicslab.org/Document....taryMotion_RotationalDynamicsPivotingRods.xmlin this example, the rod is swinging with one end pivoted. conservation of energy was used in this example. the change in potential energy was converted to kinetic energy, and mechanical energy thus was supposedly conserved. However, I have a problem with this: the net work done on a body F(dot)d where at least a component of a force acts on a body in the same direction as the direction of the center of mass' movement. the pivot point exerts a force perpendicular to the rod (and therefore parallel to its center of mass' velocity vector), thus doing work on it... so how can mechanical energy be conserved? this makes no sense
The work done by a force is F*d, where d is the displacement of the point of application. The force from the hinge acts on the end of the rod, whose displacement is zero. As long as the hinge is free of friction, no work is done by it.
Damn man, thanks. I wasn't sure b/c every time I asked my physics teacher, he kept coming up with weird explanations for it. It's funny how a little detail like that will completely throw you off.
Just as a follow up, for a frictional torque about the pivot, would the work be that force (the frictional force) times d=θ(displaced)r(radius of the pivot)
so W=Frθ?
Because the frictional forces would act all around the pivot, not just in one place, right?
so W=Frθ?
Yes, assuming that the friction force is constant.
I'd say because the surface that the hinge exerts a frictional force against undergoes a displacement as the hinge turns.
Related to Pivot doing work on the rotating rod
1. What is a pivot?
A pivot is a point or axis around which an object rotates or turns.
2. How does a pivot work?
A pivot allows an object to rotate or move around a fixed point, while still maintaining stability and balance.
3. What is the purpose of a pivot in a rotating rod?
The purpose of a pivot in a rotating rod is to provide a point of rotation for the rod, allowing it to spin freely without losing balance or stability.
4. How is the pivot attached to the rotating rod?
The pivot is typically attached to the rotating rod through a joint or bearing, which allows for smooth and controlled movement.
5. What factors affect the performance of a pivot on a rotating rod?
The performance of a pivot on a rotating rod can be affected by factors such as the material and design of the pivot, the weight and balance of the rod, and the amount of friction or resistance in the joint.
