Planar Equations applied to Robotic Calibration
In summary: Your Name]In summary, the conversation discusses the challenges of translating a software map of connector distances to a "real world" plane equation due to potential skew in the X, Y, and Z dimensions. The speaker suggests using a non-linear calibration method and multiple reference points on the grid of connectors, as well as incorporating machine learning techniques for more accurate results.
sgidley
Hello,
We have a robot whose function is to connect to a grid of connectors on the back of an industrial frame, one at a time. The robotics can move in 3 dimensions, I call them X Y and Z, where Z engages and disengages the connector.
The robotics have a software map of the relative distances of all the connectors from each other. In an ideal world, the robotics and frame would be exactly lined up with each other in every way, so no calibration would be needed. But this is not the case. There can be skew in the X & Y direction (picture the frame leaning to one side as you look at the grid of connectors) and there can be skew in the Z dimension (picture the frame and the robotics leaning towards each other, or leaning away from each other).
I can do 3 point calibration, and therefore come up with a "real life" plane equation for the plane (frame) that I am working with, but where I am stuck is how to translate my 2 dimensional map to the "real world" plane equation.
So the ideal locations are something like this (x,y):
0,2 1,2 2,2 3,2
0,1 1,1 2,1 3,1
0,0 1,0 2,0 3,0
And I would like to translate my software map, after receiving the input from 3 point calibration, to be something like this (x,y,z):
0,0,0 0.95,-.05,.01 0.90,-.10,.02 0.85,-.15,.03
My best guess is to do the following:
Use 3 corners to calibrate with: say Upper Left (reference), Upper Right, and Lower Left.
Get a linear multiplier for the difference between ideal and actual for each coordinate in each direction... so let's take Z for example.
Ideal: No change in Z
Actual form Upper Left to Upper Right, .5 in over 12 in, so .0417 per in
Actual from Upper Left to Lower Left, -.5 in over 30 in, so -.0167 per in
So now say I am connecting to a connector 8 into the right and 20 in below the Upper Left connector. Would I simply add the resulting values together to find the expected z dimension?
(2 * .0417 ) + (20 * -.0167) = -.25 in
I could repeat the same process for the other dimensions.
The other 2 dimensions would work a little different, because there is an Ideal distance.
So say reference is connector 1, connector 10 is 10" to the right (ideally), but measures 10.2" in actuality.
That then is .2" difference over 10 in, or .02" expected skew per in. Form there it is similar to the way the Z axis was done. I would then find the expected skew per in when moving in the other direction. During robotic movements, I would add the two skews together depending on how far the robot moves in each direction.
Anyway, I've elaborated quite enough I fear, but I was wondering if there is a more elegant solution than what I have thought to do so far, and if what I'm thinking to do even is correct.
Thanks!
Thank you for sharing your question with us. I can understand the challenges you are facing in translating your software map to the "real world" plane equation. I would like to offer some suggestions that may help you in finding a more elegant solution to your problem.
Firstly, I would recommend considering using a non-linear calibration method instead of a 3-point calibration. This would allow you to account for any non-linear skew in your system, which may not be accurately captured by a linear calibration method. Non-linear methods such as polynomial regression or neural networks can provide more accurate results in such cases.
Secondly, instead of using a single reference point for calibration, you could try using multiple reference points on the grid of connectors. This would provide a more comprehensive calibration and help in accounting for any variations in skew across the grid.
Additionally, you could also consider incorporating machine learning techniques in your calibration process. By using historical data and continuously updating your calibration model, you can improve the accuracy of your results over time.
I hope these suggestions will be helpful in finding a more elegant solution for your problem. If you have any further questions or need any assistance, please do not hesitate to reach out to me.
Related to Planar Equations applied to Robotic Calibration
1. What is a Planar Equation?
A Planar Equation is a mathematical representation of a flat surface in a three-dimensional coordinate system. It is typically defined as Ax + By + Cz + D = 0, where A, B, and C are constants and x, y, and z are variables representing points on the plane.
2. How are Planar Equations applied to Robotic Calibration?
In robotics, Planar Equations are used to calibrate the positioning and orientation of robotic arms. By using multiple Planar Equations to describe the desired movement of the robot, precise control over its motions can be achieved.
3. What are the benefits of using Planar Equations for Robotic Calibration?
Planar Equations provide a simple and efficient way to describe the movement of robotic arms, allowing for accurate calibration and control. They also allow for easy integration with other mathematical models and algorithms used in robotics.
4. What are the limitations of using Planar Equations for Robotic Calibration?
Planar Equations are limited to describing flat surfaces, so they may not be suitable for calibrating more complex robotic movements. They also require precise measurements and assumptions about the robotic arm's geometry, which can introduce errors if not accounted for.
5. How can Planar Equations be used to improve robotic performance?
By accurately calibrating the positioning and orientation of robotic arms using Planar Equations, their performance can be improved in terms of accuracy, speed, and efficiency. This can lead to better overall performance and productivity in various industrial and research applications.
  • Quantum Physics
  • Linear and Abstract Algebra
