Planck function expressed in Wavenumber?
In summary, the Planck function is a mathematical expression used in simulations and calculations involving wavenumbers. The first Planck constant, alpha1, is a crucial part of the function and is equal to 2 h c^2. However, there are different units for alpha1, with some sources using steradian-1/cm-4 and others using W·m². The origin of the steradian-1/cm-4 unit is not clear, but it is commonly used in astronomy and astrophysics.
nordmoon
68
I am checking some equations for my simulation and are looking at the Planck function. My question involves the constant used for the Planck function expressed in Wavenumbers. I have found this expression for the function (http://pds-atmospheres.nmsu.edu/education_and_outreach/encyclopedia/planck_function.htm) but I don't understand where the unit comes from for the first Planck constant alpha1 = 2 h c^2 = 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4? I would like to understand this before I use it. There is another expression for the first Planck constant including pi but has a different unit.
I guess I am looking for a Planck function expression which uses wavenumbers, but it would be nice to see how alpha 1 is obtained.
Planck function dependent on wavenumber w (cm-1)
B(T,w) = (alpha1 w^3)/[exp(alpha2 w/T) - 1]
alpha1 = 2 h c^2 = 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4 <-- how?
when
h is Planck's constant (6.62620 · 10^-34 Joule second)
c is the speed of light (2.99793 · 10^8 m/second)
I have found another source that
alpha1 = 2 pi h c^2 = 3.741 771 18(19) × 10−16 W·m²
Putting in the numbers I obtain:
alpha1 = 2 h c^2 = 1.19107 * 10 ^-12 W/cm^2 = 1.19107 * 10 ^-16 W/m^2
This is not, 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4 .. where does the unit steradian-1/cm-4 come from?
I might add that I did find a few papers using this number, C1 = 1.191062£10^-12 W cm^2 /sr, but it still does not explain the origin of the two unit values. (http://www.iop.org/EJ/article/1674-1056/17/11/038/cpb_17_11_038.pdf?request-id=2a611551-3e23-4cae-9cb4-58c619d41cbe) I couldn't find the original when looking at references..
From my astronomy sources, " A steradian is defined as the http://en.wikipedia.org/wiki/Solid_angle" subtended at the center of a sphere of radius [itex]r[/itex] by a portion of the surface of the sphere whose area, [itex]A[/itex], equals [itex]r^2[/itex] "
Steradians are commonly used in astronomy and astrophysics (where Planck's constant is frequently used as well). Outside of astronomy/astrophysics, I do not know where else one might find the unit used.
FAQ: Planck function expressed in Wavenumber?
1. What is the Planck function expressed in wavenumber?
The Planck function expressed in wavenumber is a fundamental equation in physics that describes the spectral radiance of a blackbody at a given wavenumber or frequency. It is derived from Max Planck's law, which states that the energy of a photon is directly proportional to its frequency.
2. How is the Planck function expressed in wavenumber used in scientific research?
The Planck function expressed in wavenumber is used in a variety of scientific fields, including astronomy, atmospheric science, and materials science. It is commonly used to calculate the thermal radiation emitted by objects at different temperatures, and is also used to analyze the composition and properties of gases and solids.
3. What is the mathematical formula for the Planck function expressed in wavenumber?
The mathematical formula for the Planck function expressed in wavenumber is Bν(λ,T) = λ / (λ5 x (eφ / λ − 1)), where ν is the wavenumber, λ is the wavelength, T is the temperature in Kelvin, and λ and φ are constants known as the Wien displacement and Planck's constant, respectively.
4. Can the Planck function expressed in wavenumber be used to calculate the radiation emitted by objects at any temperature?
Yes, the Planck function expressed in wavenumber can be used to calculate the radiation emitted by objects at any temperature, as long as the object is in thermal equilibrium. However, at extremely high temperatures, the equation may break down due to the effects of quantum mechanics.
5. How does the Planck function expressed in wavenumber differ from the Planck function expressed in wavelength?
The Planck function expressed in wavenumber and the Planck function expressed in wavelength are mathematically equivalent, but they are used to describe radiation in different units. The wavenumber version is often used in spectroscopy and atmospheric science, while the wavelength version is more commonly used in astronomy and cosmology.
