Plane flying at an angle, trying to find radius
In summary, when trying to solve for the radius of a circle the plane will be flying if the wings are banked 50.0° to the horizontal, the speed remains 480.0 km/h during the turn, and the magnitude of the lift provided by the wings is unchanged.
I_LuV_FiZiX
27
To change the direction of the plane, its wings are banked. If the wings of the plane are banked 50.0° to the horizontal, what is the radius of the circle in which the plane will be flying? Assume that the speed remains 480.0 km/h during the turn and that the magnitude of the lift provided by the wings is unchanged.
m = 13900kg (given previous to this problem) but I do not think this comes into play
I said that the forceof the lift = L. the sum of forces in the y direction = Lcos50 = mg. The sum of forces in the x direction = Lsin50 = (mv^2)/r. Solving both equations for L and then setting these expressions equal to each other, I eventually came to r = (v^2)/gtan50, giving me an answer of 19,707km. The computer keeps telling me I am incorrect.
Any help would be appreciated
Be careful with units. That speed is given in km/hour--convert to standard units.
still wrong
that gave me an answer of 1521m, which seems kind of small anyway
Looks right to me.
so do you think that it could possibly be an error with the computer? I can't see any mistake I have made.
It wouldn't surprise me, as those systems can be fussy. What units does it want? How many significant figures?
It does no specify what units it wants, or how many significant figures. I have tried many combinations of both.
Oops. I missed the implication of this:
So the following is incorrect:
This (the last sentence) is not true. Once the plane banks there is no longer vertical equilibrium.
My bad! :redface:
Your bad: Please post the entire problem.
(Thanks to alphysicist for waking me up! :smile:)
FAQ: Plane flying at an angle, trying to find radius
How does the angle of a plane affect its radius?
The angle of a plane does not directly affect its radius. The radius of a plane is determined by its speed, altitude, and direction of travel, not its angle of flight.
Can a plane fly at an angle and still maintain a constant radius?
Yes, a plane can fly at an angle while maintaining a constant radius. This is because the radius is determined by the motion of the plane, not its orientation.
What factors determine the radius of a plane flying at an angle?
The radius of a plane flying at an angle is determined by its speed, altitude, and the direction of its motion. These factors work together to determine the curved path the plane takes while flying.
How does the air around the plane affect its radius while flying at an angle?
The air around the plane does not directly affect its radius. However, air resistance and wind can impact the speed and direction of the plane, which can indirectly affect its radius.
Can the pilot control the radius of a plane while flying at an angle?
Yes, the pilot can control the radius of a plane while flying at an angle by adjusting the speed and direction of the plane. By making adjustments to these factors, the pilot can change the curved path of the plane and thus control its radius.
13K
