TheWonderer1
- 88
- 1
I saw a video recently describing the lift in terms of pressure. It stated that the Coanda's effect is important. That is the tendency of a fluid jet to flow a curved path. It stated that there is high pressure above the top of an air foil and low pressure below so the air drops or gets sucked down like a vacuum. This easily describes the curving of air on the top of an air foil but not so easily for the bottom air flow which is also curved. The video also states that the curved streamlines have higher pressure outside than inside the line. Therefore, looking at the bottom it should have higher pressure. Although, the curvature shouldn't happen with this logic if the bottom surface of the air foil has higher pressure than below it. The logic of this video seemed to be off and I just want clarification.
Also, what about the front fan of a jet engine draws the air in? I think it has something to do with the origination of the air foils themselves but basically, what causes a fan to suck in or blow out? Thank you!
