Planetary Motion: Orbit Transfers, Hohmann transfer
In summary, the thought of increasing a satellite's speed to allow it to transfer from a "higher energy" elliptical orbit to a "lower energy" circular orbit (in reference to the effective potential energy plot that arises after introducing the concept of an effective mass to simplify the two-body problem into a one-body problem) seems a bit counterintuitive. It's easy to find this illogical with a circular orbit simply occurring at a lower energy level than an elliptical orbit in the effective potential energy plot. However, Examining other equations such as ΔE = Δ(-C/A) (where C = GMm) clearly depicts mathematically why, in the final stage of the Hohmann transfer process, transferring to a
Lost1ne
47
The thought of increasing a satellite's (for example) speed to allow it to transfer from a "higher energy" elliptical orbit to a "lower energy" circular orbit (in reference to the effective potential energy plot that arises after introducing the concept of an effective mass to simplify the two-body problem into a one-body problem) seems a bit counterintuitive. It's easy to find this illogical with a circular orbit simply occurring at a lower energy level than an elliptical orbit in the effective potential energy plot.
Examining other equations such as ΔE = Δ(-C/A) (where C = GMm) clearly depicts mathematically why, in the final stage of the Hohmann transfer process, transferring to a circular orbit with a larger major axis requires an in-take of energy, gained through the rocket engine. However, how should this be viewed with respect to the effective potential energy plot (equal to [L^(2)[/[2μr^(2)] - (GMm)/r, with the remaining term being the kinetic energy from the radial velocity; μ is the effective mass, Mm/(M+m))? Would the best way to think of this be a shift in this graph due to the work done by the propellant force on the satellite (thus a new graph that allows for the new, final energy to take a circular orbit)?
Don’t yet have a conclusive answer for you, but would like to see if we can work it out together. Just off the top of my head, have you included the energy of the reaction mass (the expelled propellant) in your thinking? Also, since an elliptical orbit continuously exchanges kinetic energy for potential, the total of the two remains nearly constant, and that may be the key to understanding this. Will spend some time trying to flesh out these ideas and come back to see this thread again later.
Oooh. I don't think I thought too much about that actually. I guess I'm then encouraged to think of the "flow mass" portion of this problem? If I choose my system to be the satellite and any propellant that is exerted, I'm assuming that the energy in that system would be conserved. However, our concern should be with the energy of the satellite after it loses a bit of propellant over some time duration and then experiences some change of velocity as a result of it. The net external force on this system would be the gravity exerted on the system by the massive mass that the system is orbiting. Am I on the right track? Is it encouraged to think of the problem in this manner to answer my question more effectively? I'll return to this later.
I do believe that is the right track to follow. Was able to think about it a little, and I noticed that the Transfer burn for rounding out an orbit at the top of the ellipse requires thrust in the opposite direction from the burn required for keeping the satellite at the bottom of the ellipse. The propellant gets thrown into higher orbit when the satellite settles into a lower one, and vice versa. That seems like an important clue.
My only hesitation comes when considering that, even when settling into a round orbit with the exact same energy as the original ellipse, an acceleration is still required. That one has got me puzzled, because no orbital energy has been gained or lost, yet we had to expend energy to get there. Will continue to ponder, and return later (I’m at work, browsing the Forums during my breaks).
If the craft (not counting the propellant expelled in the whole maneuver) gains no energy, and you lose chemical energy, then the expelled propellant must have gained it (the propellant has more KE+PE than it had originally in the tank).
Likes LURCH
Ah yes, that’s the piece I was missing. Thanks A.T.
I've created a diagram.
JmM230i
https://imgur.com/a/JmM230i
After discussing this with my professor, this is what we concluded the effective potential energy curve should look like (assuming it's correct). This would apply to the Hohmann transfer orbit where our craft transfers from an elliptical orbit to a circular orbit where the craft is accelerated tangentially (thus, angular momentum increases) into a circular orbit when at the apogee of the elliptical orbit. The apogee of the elliptical orbit is equal to the radius of our circular orbit, all measured from the more massive, "stationary" object that our craft is orbiting about. My professor didn't mention the flow mass aspect of this problem, but I believe that the system analyzed in our curve will be the craft, excluding the propellant released.
Related to Planetary Motion: Orbit Transfers, Hohmann transfer
What is planetary motion?
Planetary motion refers to the movement of planets and other celestial bodies in our solar system. This includes their orbits around the sun, as well as their rotations on their own axes.
What is an orbit transfer?
An orbit transfer is the process of changing the orbit of a spacecraft or satellite in order to reach a desired location or achieve a specific mission objective. This can involve changing the shape, size, or inclination of the orbit.
What is a Hohmann transfer?
A Hohmann transfer is a type of orbit transfer that uses two engine burns to transfer a spacecraft from one circular orbit to another. The first burn raises the spacecraft's apoapsis (highest point in the orbit) to the desired altitude, and the second burn lowers the periapsis (lowest point in the orbit) to the final destination.
What factors influence the success of a Hohmann transfer?
The success of a Hohmann transfer depends on several factors, including the velocity of the spacecraft, the distance between the two orbits, and the gravitational pull of other celestial bodies. The timing of the burns is also crucial, as they must be executed at specific points in the orbit for the transfer to be successful.
How is a Hohmann transfer calculated?
A Hohmann transfer is calculated using mathematical equations that take into account the orbits of the two bodies and the laws of celestial mechanics. These calculations can be complex and require precise measurements and data in order to achieve the desired transfer.
