Plasma ball, energy levels of neon and xenon
In summary, the main part of the plasma ball's filament emits blue light due to the presence of xenon, while the end part emits pink light due to neon. The pink light is produced by the transition from level 2p to 1s in neon, which requires a kinetic energy of 18.5 eV or more. To maintain the arc, some neon atoms must be ionised with a kinetic energy of 22 eV or more. The glass wall of the plasma ball may block the emitted ultraviolet light. It is likely that most neon atoms that transition from 2p to 1s are fully ionised before arriving at 2p, and the transition from ionisation to 2p does not emit
spareine
129
39
I was wondering about the filament colors in a plasma ball that I have got. The main part of each filament is blue, but its end part is pink. Possibly the gas is 95% neon and 5% xenon, the pink part is light emitted by neon, and blue part light emitted by xenon. Using a hand spectroscope I watched the spectrum of the pink color, which was identical to the spectrum of a neon lamp, between 585 and 700 nm. These spectral lines correspond in the energy level diagram of neon to the transition from level 2p (18.5 eV above ground state) to 1s (16.5 eV), so the colliding free electrons in the filament have been accelerated to a kinetic energy of 18.5 eV or more. To keep the filament alive some neon atoms have to be ionised (22 eV), so there are free electrons with a kinetic energy of 22 eV or more as well.
Questions:
1) is the direct deexcitation from ionised neon to ground state likely, so that extreme ultraviolet (22 eV, 60 nm) would be emitted inside the glass ball? Would the 1 mm glass wall block the emitted ultraviolet entirely?
2) is it likely that most neon atoms that made the transition from 2p to 1s were fully ionised before arriving at 2p? Is it likely that the transition from ionization to 2p does not emit light? And is it likely that the final transition from 1s to ground state does not emit light?
3) why are neon atoms emitting light only at the end part of the filament, versus xenon in the main part? May be it has to do with the lower ionisation energy of xenon, 12 eV, but I don't see how.
This is interesting. To answer part 3, I believe the voltage between the electrodes would need to be just over 22 volts to have any appreciable amount of neon get ionized. The xenon probably needed to be in lower concentration in order to make this happen, or higher currents would result with attempts to increase the voltage, that wouldn't produce much neon ionization, and instead, a substantial increase in xenon ionization would occur. The voltage of the arc would be then limited to something in the neighborhood of 12 volts. With a low concentration of xenon, and 22+ volts between electrodes, the electric fields could be such that the 22+ volt region w.r.t. the cathode is achieved in the vicinity of the anode, so that if an electron was able to go from cathode to near the anode without yet undergoing a major collision, it would be able to ionize the neon. The actual physics inside the arc lamp may be somewhat more complex than this, but I think I have a satisfactory answer. ## \\ ## One additional comment: Perhaps the neon doesn't need to get ionized at all=the xenon could be furnishing the vast majority of the ionized electrons. It is possible it runs at about 19 volts. ## \\ ## Also a google of the neon spectrum shows you may have observed the 632.8 nm transition from 5s to 3p. See https://en.wikipedia.org/wiki/Helium–neon_laser#mediaviewer/File:Hene-2.png ## \\ ## See also page 4 of http://web.physics.ucsb.edu/~phys128/experiments/laser/LaserFall06.pdf ## \\ ## Alittle more googling showed the following results, so apparently the 632.8 (6328 Angstroms) line is not one of the brightest lines of a neon arc lamp: https://physics.nist.gov/PhysRefData/Handbook/Tables/neontable2.htm This listing shows about 4 rather intense lines between 6900 and 7300 Angstroms. It would appear the energy diagrams of the first two "links" are rather incomplete and simply emphasize the 632.8 nm, 1.15 um, and 3.39 um transitions.
Related to Plasma ball, energy levels of neon and xenon
1. What is a plasma ball?
A plasma ball is a type of novelty lamp that contains a mixture of gases, typically neon and xenon, at low pressure. It also contains an electrode in the center that emits high-frequency electric currents, creating a plasma inside the ball.
2. How does a plasma ball work?
A plasma ball works by using a high-voltage power source to ionize the gases inside the ball. This creates a plasma, which is a gas that contains free electrons and ions. The electric currents from the electrode excite the gas molecules, causing them to emit light.
3. What are the energy levels of neon and xenon in a plasma ball?
The energy levels of neon and xenon in a plasma ball vary depending on the gas pressure and the strength of the electric field. Generally, neon has a lower ionization energy than xenon, so it is easier to ionize and produces a brighter glow in the plasma ball.
4. What is the purpose of using neon and xenon in a plasma ball?
The purpose of using neon and xenon in a plasma ball is to create a visually appealing and colorful display. Neon emits a red-orange color, while xenon emits a blue-purple color. Together, they create a vibrant and dynamic light show inside the plasma ball.
5. Are there any safety concerns with plasma balls?
Plasma balls should be used with caution as they contain high voltages and can cause electric shocks if touched. It is important to always keep the plasma ball away from water and to unplug it when not in use. Additionally, prolonged exposure to the electric field from a plasma ball may cause skin irritation for some individuals.
  • Electromagnetism
  • Atomic and Condensed Matter
