Plate floating on oil - linear momentum equation
In summary, the linear momentum equation explains how a plate can remain in equilibrium while floating on oil due to the balancing of weight and buoyant forces. Factors such as weight, density, viscosity, surface tension, and shape influence the plate's movement on the oil. The linear momentum equation can be used to predict the plate's trajectory if all relevant forces and initial conditions are known, but real-world factors should also be considered. The plate's shape affects its movement by changing its surface area and frictional forces. The linear momentum equation is applicable to all objects floating on fluids in equilibrium and is a fundamental principle in fluid mechanics.
Pietair
59
1: Determine the wall shear stress that acts at the lower side of the plate.
2: Determine the force Fx that is needed to give the plate a speed of u = 1m/s.
3: Determine the speed V, that is leaves an air jet that blows against the plate and which creates the same force Fx.
Question 1 and 2 were easy to solve, but I have got a problem with the third question.
Linear momentum equation: [tex]\sum \vec{V}_{out} \rho_{out} A_{out} V_{out}-\sum \vec{V}_{in} \rho_{in} A_{in} V_{in}=\sum F[/tex]
The left part of the linear momentum equation is easy to find. However, I don't understand which forces I have to include when applying the linear momentum equation in the x-direction.
I know that I have to include a force -Fx, which is the force exerted by the plate on the control volume (which is the reaction force of the force exerted by the fluid on the plate).
But in the answer sheet they do not include the pressure force exerted on the left side of the control volume, which I think should be P_{atm} * the left area of the control volume (because the pressure in the air jet is simply P_{atm}. Why isn't this pressure force on the control volume included?
Thank you in advance.
Thank you for your post. It seems like you are on the right track with your solution for the third question. However, there are a few things to consider when applying the linear momentum equation in this scenario.
Firstly, you are correct in including the force -Fx in the equation as it is the reaction force of the fluid on the plate. However, you also need to consider the force exerted by the fluid on the control volume, which is equal to the force exerted by the plate on the control volume (-Fx). This is because of Newton's third law of motion.
Secondly, you are also correct in considering the pressure force exerted on the left side of the control volume. However, this force is already accounted for in the linear momentum equation as it is included in the term \sum \vec{V}_{in} \rho_{in} A_{in} V_{in}. This term represents the momentum of the fluid entering the control volume, which includes the pressure force.
In summary, when applying the linear momentum equation, you need to consider the force exerted by the fluid on the control volume (-Fx) and the momentum of the fluid entering the control volume, which includes the pressure force. I hope this helps clarify your doubts. Good luck with your calculations!
FAQ: Plate floating on oil - linear momentum equation
1. How does the linear momentum equation explain plate floating on oil?
The linear momentum equation, also known as Newton's second law, states that the rate of change of an object's momentum is equal to the net force acting on the object. In the case of a plate floating on oil, the plate's weight and the upward buoyant force from the oil are balanced, resulting in a constant momentum and the plate remaining in a state of equilibrium.
2. What factors influence the plate's movement on the oil?
The plate's movement on the oil is influenced by various factors such as the plate's weight, the density and viscosity of the oil, and the surface tension of the oil. These factors determine the magnitude of the buoyant force and the frictional forces acting on the plate, ultimately affecting its movement.
3. Can the linear momentum equation be used to predict the plate's trajectory?
The linear momentum equation can be used to predict the plate's trajectory if all the relevant forces and initial conditions are known. However, in real-world scenarios, other factors such as air resistance and surface imperfections may also affect the plate's movement and should be considered in the prediction.
4. How does the plate's shape affect its movement on the oil?
The plate's shape can affect its movement on the oil by changing its surface area and, therefore, the amount of oil displaced. A larger surface area results in a larger buoyant force, while a more streamlined shape may reduce frictional forces, allowing the plate to move more smoothly.
5. Is the linear momentum equation applicable to all objects floating on a fluid?
Yes, the linear momentum equation is applicable to all objects floating on a fluid as long as they are in a state of equilibrium. This equation is a fundamental principle in fluid mechanics and can be used to understand and analyze various phenomena, including the floating of objects on fluids.
